Question about Mitsubishi Heating & Cooling
Car over heats and heat won't turn on. What could the problem be?
What make of car ??
Posted on Oct 02, 2008
1990 lincoln town car 5.0 heater won't heat, but the fan and the air conditioner works fine, a new radiator was installed also before i bought it...engine don't seem very hot ..????
If the engine is not getting up to normal temp, I would replace the thermostat. Both heater hoses have to be hot to get heat inside the car.
Feb 03, 2013 | 1990 Lincoln Town Car
Why won't my car heat up in the winter?
Is the problem with the engine or the heater, or both ?
If the engine is not heating up, it could be a faulty thermostat.
Jan 23, 2013 | 2000 Pontiac Grand Prix
My heat doesn't work.
Check the coolant level...if it's low the heater core in the car won't make heat.
Does the fan work?
GL,
Td
Oct 06, 2012 | 2001 Saturn L-Series
My 1999 grand am over heated and now my car won't
check the heating relay under the motor near your water pump
Jul 31, 2012 | Cars & Trucks
My ac or heat won't work
For the a/c, you may be out of refrigerant, and need it to be refilled.
For the heat part, it is most likely one of the following things: low coolant, thermostat, heater core, or maybe even radiator malfunctioning.
If you need some diagnostic tools to test the A/C, I recommend the actia multi-diag.
Jul 15, 2012 | 2003 Mercury Grand Marquis
1998 VW Beetle Notice cooling fans are not coming on. Air still works but car quickly them over heats. Also over heats when stuck in traffic. I have been turning on the heater when stuck in traffic and the...
Did you check the coolant level? if your low on coolant the sensor for the fans won't work, also could be a bad fan motor or just a fuse, if you continue to over heat the car you can do a lot of damage to the engine, blown head gasket, and the VW's are expensive to repair, take it to a good shop and have them check it out.
Aug 26, 2011 | 1998 Volkswagen Beetle
Car is over heating, boiling in the overflow, this after 5km's the oil looks fine ?????? help
Check your coolant levels and make sure the hose between the coolant reservoir and the radiator aren't clogged. The cooling fan on the radiator may not be directly driven by the serpentine belt and may be on a clutch. If the clutch is broken the fan won't cool the radiator and the radiator won't cool the car. Get the car good and hot and see if the fan kicks on. To temporarily relieve the overheating in the engine, turn the heat on in your car.
May 04, 2011 | 1989 Toyota Cressida
Car runs fine till it is turned off
two things come to mind....
1- a electrical component may be heat sensitive and not function after turn off heat soak
2- your fuel pump check valve isn't holding fuel pressure in the fuel loop
Next time check for spark...if thers's spark it's a fuel problem
Mar 24, 2009 | 1997 Oldsmobile Achieva
Heating & Cooling Logo
18 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
