Question about HP Pavilion zd8000 Notebook
Hp pavilion f1523 lcd monitor
Problem with hp pavilion f1523 lcd monitor. thin , faint yellow colored horizontal lines from top to bottom of the screen which keeps flactuting.
You are not alone with this problem. Some lines (like mine) run vertically rather than horizontally. The solution - sue HP. These screens have a known fault ie the Nvidia graphics chip is known to be the culprit. The company knows all about this issue but expect us to pay to put it right - sue them, you can do it online for around £35 (UK).
Posted on Oct 29, 2008
  • 54 Answers
I had an lcd moniter that had red lines through it so I replaced the tower and the lines went away. Although, this is a laptop instead of a moniter.They are similar but different because the display is attached together on a laptop. A lot of people would rather fix the display or throw away the laptop. The lines running through a display happens when an lcd inverter is giving up or burning out. The colors on the display are affected and the ending result is faulty lines or a blank screen. http://www.laptoprepair101.com/laptop/2006/08/17/bad-video-on-lcd-screen/ There are ways to test them but it takes time and equipment http://www.fonerbooks.com/test.htm I have also found some lcd inverters that are not so much costly http://www.yallstore.com/laptop-notebook-inverter-c-720_1058.html?filter_id=9&gclid=CPi149S44JYCFRsRagod3RZOPA
Posted on Nov 06, 2008
My Hp pavilion f1523 screen keeps flickering when I swicth on the computer. The monitor has to be switched off. I have to wait a long time & then turn on the monitor then only will I be able to view...
Check for bad caps with bulging tops/bottom seals in the power supply first, very common problem in all LCD monitors as you can see in my albums here:
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Post back what you find.
Sep 09, 2011 | HP Pavilion F1523 15" LCD Monitor
Pavilion F1523 15" LCD Monitor: will not power up...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 18, 2010 | HP Pavilion F1523 15" LCD Monitor
HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1523
Open the screen and on the backside there are two pcb's.
Left is the power conversion unit and right is the hardware for the display. I had the same problem. So on the left one you will find a lot of capacitors (ELCO). Look for those ones with a rounded top. note their capacity and current (most fragile are the 16V470uF and 16V1000uF). Replace the ELCO's with rounded tops. NOTE THE POSITIVE AND NEGATIVE SIDES!!! DONT SWAP THESE or you will end up with another one with a rounded top. Solder it all together and close the screen. Your problemo is solvento!
Oct 10, 2007 | HP Pavilion F1523 15" LCD Monitor
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
HP Pavilion zd8000 Notebook Logo
330 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
