Question about Toshiba TEC B-882 Thermal Label Printer
Paper jam machine keeps coming up paper jam i have replaced sensors and tried to set up but still saying paper jam? can you help?
The paper jams in the bottom because the leading edge hasn't reached the correct sensor in time, thus causing a jam message. Do a sensor test on the front panel of the printer before replacing any parts. Go into Diagnostics/Sensor test and you will see the letters across the top follwed by numbers below. Then you want to toggle the sensors located through out the paper path-usually black plastic hanging done into the tray areas. Up in output tray has black plastic hanging down-sensors. lift top cover and you can see the sensors on the left side of the top a black horseshoe shape is a sensor. This will help with the correct parts needed to be replaced.
Posted on Oct 02, 2008
Paper won't feed through
Look for a paper sensor at the bottom of the stack and see if it's jammed; look for jammed paper in the machine.
Sep 08, 2014 | Office Equipment & Supplies
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
I have a K60 xi printer that had a paper jam and the jam was fixed but I can't the paper jam notice off of the screen.
On these machines, a second look inside the machine might help. Some sensors are deep inside. The actuators are very small, and you can miss them completely. Use a flash light and observe all areas for a sensor actuator. It may have gotten pushed off its position slot.
Some machines have glass sensors. Sometimes paper hole punches get down in there and will rest on a sensor. This will keep the machine from operating. Paper dust can also cause these sensors to keep the machine from coming back to a ready.
Check the document feeder to see if all actuators are working correctly. On some machines, the sensor may complete come off its correct position and will have to be put back in its original position in order for the machine to know to come back to a ready state.
Good luck.
Aug 12, 2010 | HP OfficeJet k60xi InkJet Printer
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
My fax machine keeps saying there is a paper jam.
look on the bottom of your drum unit. there is a sensor opening that might have a tiny piece of paper in it, not allowing the sensor flag to reset. if thats not it, closely inspect behind rear door.
hth,
razors
Apr 05, 2009 | Brother MFC 8500 All-In-One Laser Printer
False Paper Jam Message
Probably a jam sensor is dirty or stuck. Look through the paper path for a stuck plastic sensor arm, or dirt or paper dust on photocell typr sensors.Paper sensors are normally located near where paper feeds, and where it exits the machine. The paper must pass over these sensors as it travels through the machine.If a scrap of paper is left on the sensors, they will report it as a jam. If you can, try manually pushing a sheet of paper through the printer, ONLY in the direction it normally feeds. This may free up a stuck sensor arm, or force out the jammed scrap.
Jun 08, 2008 | Brother MFC 420CN All-In-One InkJet...
XEROX TELECOPIER 7024
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Mar 26, 2008 | Office Equipment & Supplies
Panasonic workio sp-190 machine says paper jam
This series of machine has frequent issues with the sensors in the paper path to detect timing and position. The sensors are actually optical but the utilize sensor"flags" to interrupt the sesnors light "beam". These sensor flags tend to pop out of position and/or break the springs. I have also seen the actual optical sensor fail.
Dec 24, 2007 | Panasonic Workio DP-2500E Copier
Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Oct 03, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Toshiba TEC B-882 Thermal Label Printer Logo
247 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
