Question about Compaq (010391-001) Motherboard
Compaq-TPN10-01-Motherboard I need to know what to click to get into bios for compaq Also Need jumper settings or manual for the same
  • 781 Answers
F1 / DEL / CTRL + ESC / F2
Try any of the above
Posted on Oct 04, 2008
    New Friend:
Http://www.elhvb.com/ctechinfo/msgs/4951.pdf
manual for you can find all about this board jumpers ,all)
Posted on May 21, 2016
Getting into the BIOS is one thing, but figuring out what the jumpers and the headers on the Board itself without a Manual is pretty hard.
Posted on Jan 06, 2012
  • Bob Knippel Dec 23, 2012
    The BIOS jumper ought to be fairly well identified if it has one, but that might be an issue, as some motherboards do not have one. I have a different COMPAQ motherboard which has no provisions for a corrupted BIOS recovery. Without access to drives, there is no way to rewrite the BIOS.
I have a HP DV7-1175NR and I can't get access due to a problem with the password in the bios. For some reason It doesn't recognize my password. I need to know if you have any idea how to reset the bios.
HP/Compaq/Acer InsydeH20 Bios Password Service
with 8 digit HashCode
Support model: Compaq CQ40, Compaq CQ45, HP DV3, HP DV4,DV5....
We can help you remove this password.
You just entering 03 times wrong password, then your screen will show 8 digit code number (view below image):
Let's me know your 8 digit code and Model Name ( mr.tran7000@gmail.com)
GO TO >> Master password - Bios Password
Apr 11, 2011 | HEWLETT-PACKARD Pavilion dv7-1175nr PC...
Sirs I have not made any password for entering bios setup for compaq presario x1370 us, but when try to enter bios setup by pressing F10, display for administrtor password appears. What password could i...
But there is no need to worry. There are many known ways to reset / remove / bypass the password: Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings. If it fails, then try to remove the battery for at least one hour. B. By Using the Motherboard Jumper: Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin. Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Feb 25, 2011 | Compaq Presario X1370 Series Laptop...
Compaq 8150p bios password need to be reset. Is the cmos battery soldered on or unplugable.
The BIOS battery could be a button type battery or it could be a battery with a plug-in lead.
Oct 08, 2009 | HP Compaq 8510p Notebook
Smsc motherboard jumpers setting(compaq presario 5000
no need jumpers, the smsc are being setup in the BIOS, enable it or disabled... go to BIOS Setup
Jun 19, 2009 | HP Compaq Presario 6310US (DA201A#ABA) PC...
I have motherboard Compaq #277498-001 P5008640WP8N2BSM AS#253242-002 DG#011346 and can't find information for jumpers setting, please for help-marior77@abv.bg
What model does this MB belong to? If it is a newerMB the only jumper settings you should see would be the clear BIOS jumper. Alot of the newer motherboard settings are done thru the BIOS.
http://www.compaq.com/cpq-country/cpq_support.html
try looking here
good luck
May 16, 2009 | Compaq ( 277498-001) Motherboard
Bios password
The master password for Compaq is "compaq"
If that doesn't work you need to use a jumpe on the motherboard:
This Jumper is often named like: "RTC_CLEAR" , "CLEAR CMOS" , "CLRCMOS" , "CLRCMS". His position is often near by the motherboard battery. You will need to reconfigure any BIOS changes that you have done.
Mar 17, 2009 | HP Compaq Presario V3000T Notebook
Old compaq presario new processor
The AMD K6 II / 350 has a 100 MHz bus speed and a 3.5 multiplier. I was online with a tech at HP and even they don't know, but if they send the motherboard manual as promised and it has the info I'll post a comment. They did say it can't be done in the BIOS. I can tell you often the major manufacturers used boards where the jumper locations were soldered and didn't even have pins to change the settings, making it pretty hard to upgrade the processor.
Do you see any jumpers on the board at all? Sometimes the multiplier & clock speed info is printed right on the board in tiny white letters.
Good luck.
Jan 01, 2009 | Compaq (283983-001) Motherboard
No boot
Hi:
You need the manual.
You also need to know what bios you have.
Take the battery out for 24 hours.
Most motherboards I have worked on will not discharge in only a half hour. You need a lot more time than that.
You can also clear the cmos on the jumpers. Be sure you know which jumpers, otherwise you may damage the board.
By shorting two of three jumpers, the cmos will be cleared to factory settings.
thanks,
Aug 31, 2008 | Compaq Presario 1200,1600, Series CD...
Compaq presario 5340 motherboard jumper setting
search for the manual on the net.use its model number placed near the cpu socket.
May 22, 2008 | Compaq (252608-001) Motherboard
Computers & Internet Logo
331 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
