Question about Apple eMac Desktop
17inch screen only uses 8inches
Hello my emac works fine except that the 17inch screen only uses the middle around the edges it's black.It's like having a 8 inch screen is there a fix or do i throw it in the bin.thankyou
  • Justin Goldberg May 11, 2010
    I believe this info from wikipedia let's us know that this is commonplace. To quote it:
    To Apple's detriment, a number of eMac machines have suffered from what
    was known as "Raster Shift", a strange phenomenon where the bottom
    third or half of the screen goes black, with the rest of image shifting
    upward and out of the top boundary of the display. Serious static also
    accompanies the problem, rendering the viewable part of the screen
    virtually useless. In response to the problem, Apple offered a solution
    which involved the replacement of a video cable inside the eMac's case.
    Here's some links on apple.com regarding this.
  • Krabby May 11, 2010
    There could be a couple of things wrong with the unit, first I would try a software update, that will take care of any software issues with the unit, second the unit may think there is an external monitor connected to it, check the displays system preference and see if a second monitor shows up, if so turn off the mirroring aspect and the screen should go back to normal
It is simple.  Reset the PRAM (command-p-r)
Posted on Dec 09, 2008
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
Black emac screen
Hi, this could be a number of things but the most likely cause is probably the leaking capaitor syndrome.At about the time these machines were made there was a flood of faulty capacitors throughout the electronics world and the factpriews that made the mother boards for the eMac were particularly badly hit.Did the screen exhibit any flashing or streaking or random freezing before the failure? Thses are typical precursors.
Unfortunately the only thing you can do is to take it to a (Apple) repair centre where they will be able to judge if it is repairable or not.The leaking capacitors quite often ruined the mother-board. If theyu were caught in time they were repairable but .......
If the eMac is still running, connect it to an external monitor and then clone your HD to a blank HD using Carbon Copy Cloner or SuperDuper.
Jan 08, 2012 | Apple eMac Desktop
Monitor won't "sync"
Analysis procedure on this one is straightforward, though equipment intensive.
1) Put a different display on the Mac and see if it works better.
2) Put a different computer on the display and see if it works better.
Until you do this, we don't even know what component is at fault. Once we do, you can proceed from there.
Aug 18, 2009 | Apple eMac G4 Desktop
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Black box on JVC screen
a black box is covering my tv screen except for around the edges. I can use the dvd player, but i cannot watch cable. it is as though there is a security feature to block tv, but i cannot get it to go away!
Jul 11, 2009 | JVC AV-32D305 32" TV
EMac stuck on loading screen
Well i don't know of a fix for the issue u have, but i do have a tip and you might be able to fix the issue you have this way as well. But if you plan on transfering files from one mac to another esp. if one is either an older mac or a portable. you would always want to make one or the other a target disk instead of two stand alone mac's.
Why, because your eMac's older and the data transfer might be failing or can't process the data fast enough to get broken down to bits to be put back on the other end thru the cat5 line. But to transfer files of over 1 GB i would recommend you start the iBook in target disk mode. But since your eMac is the one with some issues put the eMac as the target.
To connect two mac using TDM (Target Disk Mode) you will need to get either a 6-pin IEEE to 6-pin IEEE firewire 800 cable, a 6-pin IEEE to 9-pin IEEE firewire 800 cable, or a 9-pin IEEE to 9-pin IEEE (if your eMac has a 9-pin port) firewire 800 cable.
Then you connect the cable to one of the eMac's 6 or 9 pin ports and the other end to one of the iBooks firewire 800 ports. (the iBook has both the 6 pin a48d559.gif and the 9 pin. 24a3000.gif800 ports) To start up as the target disk you press and hold T immediately after pressing the power on button. once you see the firewire symbol bounce around the screen you can let go. Now its like connecting to a external hard drive.
Jun 18, 2009 | Apple eMac Desktop
Sony 43 inch rear projection tv, I have lined up the convergence but still seeing red and green around edge of the tv on the images, seems fine in the middle of the screen though.
Always start at the vary center of the screen with Green. Position Red over Green, then Blue over what now will look yellow. If all is perfect except the outside, you will need to adjust "Mid-Size" until the middle is just as far off as the outside lines. Then adjust the main "Size" adustments to match. Go very slow or you can make a mess of it.
Mar 06, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen turns black except for one inch around the outer edge
Use the tv/cap/text button to turn off the text box function of the closed captioning.
Jan 26, 2009 | Sansui COM3101 13" TV/VCR
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Apple eMac Desktop Logo
60 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
