Question about HP Photosmart C7180 All-In-One InkJet Printer
Photosmart 2575 printer is offline - won't print
Am not computer saavy, have two computers and the HP into a "switcher" that then is hooked to single DSL line. Older computer has XP and the new one has Vista. New computer has two printers listed on printer section of Hardware and Sound on Control Panel - 1. Microsoft XPS Document Writer, printer status Ready, 2. HP Photosmart 2575 (set as default), printer status Offline. Printer works through old computer, will not print through new one - job spooled on queque. What the heck is the XPS Document Writer? Afraid to delete it not knowing what it is and how do I get the Photosmart Ready, i.e. change status from Offline. Please make explaination simple. Thank you for any suggestions. I'm having the same problem as the one described in that i install the software and i'm good to go. but when i disconnect my notebook (vista OS) from the wireless network and re-connect again i still see the peinter but its offline. i cannot get it to go online. I even tried to open the printer window and click 'connect' on the menu but the 'connect' option is greyed out. So i keep having to re-install the printer every time i re-connect to the network.
Someone please help.
  • 234 Answers
In Vista make sure you are logged in as a administrator whenever you make any changes.
And if not to bring the printer online you will have to right click on the printer icon and right click on Run as administrator> and then try bringing the printer online and checdk if it works.
And you can delete the Microsoft XPS Document writer it is a default printer icon installed if in case you did not have a printer installed you can store them to print later.
Now that you already have a printer you can delete the Microsoft XPS Document writer.
Good Luck
Posted on Oct 04, 2008
3 Suggested Answers
oldnovii
  • 667 Answers
SOURCE: Photosmart 2575 printer is offline - won't print
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 09, 2008
PyroPCMan
  • 405 Answers
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Posted on Jul 01, 2008
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Installing an hp photosmart 2575 all-in-one printer to an hp 1702 dersktop computer without the software.
if your running windows xp or vista, printer should install if powered on and plugged in to computers usb port
Sep 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
I have a HP 2575 photosmart 2575 All in one series
Are able to print? If yes, please tryy to scan by using Ms Paint. If you can scan from Ms Paint please reinstall the scanning driver software. You can download the full feature drivers and softwares from www.hp.com.
Mar 18, 2009 | HP Photosmart 2575 All-In-One InkJet...
Unable to print or scan with HP Photosmart 2575 to new Vista
That means that the printer software installation is corrupted.
You need to reinstall the drivers for this printer.
If you have original printer disk, use the disk to reinstall the printer.
If you have misplaced the disk, then you can download driver from link below:
HP Photosmart 2575 All-in-One Printer
Run installer file after download has finished.
Start driver installation with printer USNB unplugged, the printer setup wizard will tell you when to connect the printer to computer.
Set the printer as default when asked.
Feb 17, 2009 | HP PSC 2410 All-In-One InkJet Printer
Good Day,
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
Photosmart 2575 instant share
I installed the free software from HP's website. Simple as that.
May 21, 2008 | HP Photosmart 2575 All-In-One InkJet...
Jeff
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
Not Printing!!
hmmm..well..this is a fractured driver issue for certain. I have some notes on this in my Tips and Tricks section, you may find of some value.
Apr 26, 2008 | HP Photosmart 2575 All-In-One InkJet...
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
477 people viewed this question
Seeker5211
Seeker5211
