Question about Toshiba Satellite 1405-S151 Notebook
Mini pci wifi for toshiba 1405 s-171 laptop winxp
Hello, I'd like to get a minipci card from among the following since I need to use up a 70dollar credit with this company...
http://microcom.us/wireless-lan--mini-pci.html
Will any of these work? Or must I use a Toshiba mini pci card?
thanks so much. brad .
  • Andrew williams Oct 02, 2008
    I have an open minipci slot on the bottom with two U.FL antenna pigtails inside
  • Toshiba Master
  • 2,794 Answers
As long as you have an open minipci slot, they should work. The antenna pigtails should plug into the card as well.
Posted on Oct 03, 2008
Gateway 600yg2
I may not be understanding what you are stating, so bear with me;
1) The Wireless Modem antenna wires are up in the Display Assembly,
http://www.mundocorp.com/shopexd.asp?id=1160
In otherwords they should already be there.
2) The 802.11 Mini PCI Card, is a Wireless Module.
It goes in the Mini PCI Compartment, under the Mini PCI Compartment Cover, located on the bottom of the laptop.
It's made by Broadcom,
(Gateway 6002672 part number)
http://support.gateway.com/s/Mobile/NETWORK/Wireless/6002672/6002672mv.shtml
See at the Top right where it states Main, and has a white Side Arrow?
This terminal is where the Black wire (Lead) of the wireless antenna connects to.
The other terminal, AUX, is where the White wire connects to.
http://www.laptops-we-r.com/prestashop/gateway-6000-parts/418-gateway-dell-broadcom-bcm94306mp-b-g-mini-pci-wifi-card.html
Here is the Service Manual, (PDF file form),
http://support.gateway.com/s/Mobile/Gateway/600YG2/8508798.pdf
Page 13.
REMEMBER, remove ALL power. Remove the AC adapter (Charger), and Battery, before working on the laptop. Also follow Anti-Static Precautions.
Regards,
joecoolvette
Aug 20, 2012 | Gateway Computers & Internet
How to install wifi in dell c610
Download the file and the run the installer,
Dell c610 laptop wifi drivers "Dell True Mobile 1150 Series Mini-PCI Card" for WinXP
Hope it helps
May 18, 2011 | Computers & Internet
Need drivers for wireless mini lan card for Toshiba Satellite 1900-704
http://www.downloadatoz.com/driver/download_124691,toshiba-satellite-m35x-s3491-intel-802-11b-g-mini-pci-wifi-driver-8-0-12-9000w2.html
copy this url and paste it in your browser and lunch.the download button for your driver will appear for your download.install/run setup.exe after ward and your problem would be fixed.
rate this solution please
Nov 24, 2010 | Intel Toshiba Satellite Mini-PCI Laptop...
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
Mini PCI WiFi Card (PS460 FCC Id:CJ6P5460WL) driver for Win 2000 (originally Win 98 SE) Old driver:Lucient 1.6.25.6 of 2000/09/20
You can check the following link for the drivers availability
http://support.toshiba.ca/support/Download/ln_byModel.asp
Feb 11, 2010 | Toshiba Satellite Pro 4600 Notebook
Hi ,I need to install a part into my Latitude d610[wireless]
You did not specify what you needed to install.
Here is the service manual for the D610 - should assist you with taking the entire laptop apart - if needed.
http://support.dell.com/support/edocs/systems/latd610/en/sm_en/index.htm
If you want to replace the wireless NIC, you will need to look at the section marked "Mini PCI Card".
These are good directions - as long as you follow all of them.
Nov 20, 2009 | Dell (Y8029) (0Y8029)
Can't use wirelessly
Assuming you're trying to go wireless with an internal mini-PCI wireless card - this series laptops has lots of incompatibilities with WiFi cards. This one I know for sure works well: MPC13A-20/R. It's an 802.11b card and it flies. Get it.
Apr 29, 2009 | Toshiba Satellite 1905-S303 Notebook
Installation of a mini pci card for a toshiba satellite 1405-S171
What model Toshiba do you have, and what is the make and model of the card?
Aug 13, 2008 | Computers & Internet
IBM R40 2722 1802 Error Message
This is due to the fact that IBM laptops have a list of accepted devices, and the pci card is not recognised in the list. On IBM - Amilo, Mini PCI card slot is usually at the back of computer. Locate and remove Mini PCI wireless card, you will not have integrated wireless after this.
Other solution is to find the option to disable mini PCI in bios settings.
Here is how mini pci wireless card looks like:
May 28, 2008 | IBM ThinkPad R40 2722 Notebook
Toshiba Satellite 1405-S151 Notebook Logo
304 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
