Question about Epson Stylus Photo R220 InkJet Printer
Epson stylusphoto r220 inkjet
Have two red flashing lights on my r220 and doesnt work.
Both red lights flashing r220
Posted on Feb 25, 2009
  • 1,183 Answers
The problem could be caused because of a paper jam
Follow the wizard below to help you pin point the problem
http://tinyurl.com/3ou6qw
Select the option "NONE OF THE ABOVE", to move forward with the wizard.
Thanks
Proton
Posted on Oct 02, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red light flashing
Red light flashing means the cartridge near end of life or empty. You need to replace it.
Oct 02, 2010 | Epson Stylus Photo R220 InkJet Printer
2 red flashing lights on epson r220 printer
Normally indicates the ink counter needs resetting the following utility will do it make sure you read AND FULLY UNDERSTAND THE INSTRUCTIONS.
http://www.ssclg.com/epsone.shtml
Aug 11, 2010 | Epson Stylus R220 Photo Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
May 27, 2009 | Generic Memory EPSON STYLUS PHOTO R220 w/...
R220 is not working
If you have done an ink replacement and you still get the lights.
you must download the newest reset tool.
CLICK HERE and go to the bottom of the page and agree to download file.
Sep 16, 2008 | Epson Stylus Photo R220 InkJet Printer
RED LIGHT FLASHING
Hi there, i had the same problem but now it is solved by installing this program SSC on a windows and i reset the printer from there, and it worked.
Sep 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Blinking red lights
I have a canon s630 and the yellow light blinks 7 times and green once, what is causing this and can i reset this printer?
Aug 14, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson r220
The printer may have an internal error or a hardware issue already.
Ink pads full usually indicates if all lights are flashing and an error msg would pop up in your computer screen "parts inside..."
Here's what you may want to try.
Just turn off the printer.
Checked for obstructions or any foreign objects inside the printer.
Try to check from inside the printer where the ink cart holder is, from where you load the paper and from where the paper comes out.
Jun 05, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
570 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
