Internet Sharings Dear Sir, How can I sharing internet in windows server 2003 client..................Without us of switch or router....Can I create My proxy server ? So How Sir....Plz gide me......... Thanksssss Paresh(chhowala_paresh@hotmail.com)
  • Paresh Chhowala Oct 06, 2008
    Dear Sir,
    Thank for Reply But Sir In Win Server 2003, I m not find that Option(Internet Sharing) of lan Card Properties....And 'This is a Education School & Here I m installed Server 2003 with Dc & I m Connect all pc(15 PC) on 100 Mbps Switch.......My Server has 2 Lan Card, 1 for Lan & 2 for Internet BroadBand But My Problem is running On.... Plz Sir Give Me Some Others idia for Internet Sharing ????????..........
    Paresh Chhowala
  • 59 Answers
Hi
first of all can u plz tell me how do u connect to internet like u use a connectiode or something if yes its very easy u just need to right click on the connectiode & just go to properties click on the advance tab & under the internet connections sharing put the check mark on allow other network user to connect to internet through this computer internet connection thats it. u will be able to access the internet on all the pc on ur network. incase if u still have any problem just let me know & also provide the details on ur network like how u connect, any router hub or switch is been use for connecting pcs etc
Posted on Oct 03, 2008
Dear sir can you tell me how to secure internet sharing no one use internet without my permission on wired lan (Static IP) in windows 2003 or xp and how to view who is use my internet (without proxy).
On a wired LAN, the easiest way to stop someone on your network from using the Internet is to connect only your computer to the DSL or cable modem.
Jan 19, 2011 | Computers & Internet
I have a windows 2003 SBS Standard Edition and IP Address: 192.168.1.5 also a Linksys WRV210 and the IP address 192.168.1.1 I have setup a preferred DNS on all clients to 192.168.1.5 The internet is not...
For that connect your router to directly to lan ports of your server.and install another ethernet lan card on server so that ports connect with switch.
Then configure your router as bridge connection then set dns as your server ip in all computers.Then you can get 100% fast internet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 15, 2009 | Computers & Internet
Windows 2003 SBS Standard Edition ? IP Address: 192.168.1.5 Linksys WRV210 ? 192.168.1.1 Screenshot Router setup page: http://img205.imageshack.us/img205/3889/capture1w.jpg I have setup a preferred...
hello, is your server 2003 setup as DNS server??? if so have you configured forwarder for non- local access? is that a home? or business? is it work do you not have a static public IP address.
here whats happening, when you manually give client the DNS they can resolve everything local fine but when a request for outside world is sent your server doesn't know what to do with it. log on to server open up your dns console, right click on your domain, then select properties, find forwarder tab and add a any reliable public DNS server there ( ie I use 4.2.2.1 (att)) server pretty quick and reliable.
so next time a request is sent to your server and server doesn't have that information it forward that to the public DNS and you will be good to go.
but from your setup i am gathering there is plently you do to improve your network and reduce your headache of manual work.
typical setup: 1- setup DNS with forwarder
2- Setup DHCP on Server instead of router ( trust me its easier than you think)
3- put all setting to for clients in DHCP options
4- reserve IPs for servers/prineters/switches etc.
5- set all clients for DHCP
6-disable DHCP on router.
let me know if your need help setting it up.
i hope this helps
good luck
Amar Sondhi
Dec 07, 2009 | Computers & Internet
Use static IP addresses. Do not DHCP from the router. Still use the same DNS and gateway. Just specify an IP address for each one, preferably not in the DHCP range used on the router.
Dec 07, 2009 | Microsoft Windows Server Standard 2003 for...
Cant configre printer sharing via web on win server 2003
Yes is possible. Use Routing and Remote Access facility from Windows 2003 server to create a VPN Server. Create a VPN connection to Windows server, and thus you get an IP address from windows 2003 server and you can use printer.
Jul 07, 2009 | Microsoft Windows Server 2003 R2...
Win server 2003's drive c: is access to all client computer
Kindly revert for further analysis - for the points below
1.as said above - have you shared c:\ for clients ?
2.Are you using Terminal server - without security policy ?
3.is Your client directing logging in the server ?
if not any of the above please explain - ur problems in point specification.
Regards,
Sushil
sushil.mudaliar@gmail.com
(mail me across in case of emergency)
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Internet sharing
Hello Sir ''''''''''
>>>>>> u;r using dial up or broad band connection i do't know ok anyway connect u;r internet connection u see Taskbar right side Blink two computer's Dubble click that computers see some Option Below
######### Click Properties Go to Advanced See (internet Connection Sharing) this below -- Allow other network users to connect through this computer's internet connection. one box is thair Click that box right Mark ok byy
Apr 17, 2008 | Microsoft Windows Server Standard 2003 for...
Windows 2003 server standard edition
You have to enable routing and remote access in win2k server to share your internet connection
Follow these steps
Goto start--> programs-->administrative tools --> routing and remote access
Just click it
In the action menu click add server and select your server in the list
Once routing and remote access is properly installed in the server
Go to the client give gateway address to your server address and any internet DNS server addresses , and you can now acccess the internet
You can also use any internet sharing software , In this case i sujjest to use Sygate Internet sharing software
Good Luck
Jan 27, 2008 | HP Compaq ProLiant ML330e Server
How to set up a security setting on my WBR-1310 D-Link router
Dear Sir/Madam
My compu name = manta
Installed windows server 2003
This administrator is the user name
Password = manta@123
In this manta system I created one limited user
User name = server
Password = server@123
In manta server in administrator user, I installed one software in D:\ shree this is shared folder
Means that path is \\ manta\d$\shree\setup.exe
I want access which I given in the path in client system.
But when user runs this software its asking server user name & password
I can’t type or give server user name & password again and again to client .
My mail id is manta4727@gmail.com plz send the answer. Thanking u
Jan 21, 2008 | Broadcom BCM5705 Network Adapter
Connecting to network
[QUOTE]The exact error message should be:
"Windows was unable to find a certificate to log you
on to the network [SSID]"
Google shows 37 hits with this exact phrase.
This is caused by setting the encryption to WPA-RADIUS instead of
WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it
will work.[/quote]
Jan 16, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
