Question about i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case
Macbook and i-rock
Hi, I am glad you exist! I have been using windows and backing my material up on i-rock. Now that I moved to Mac, i-rock does not accept any move from Mac. However I can transfer the material from i-rock to Mac. How can I use my i-rock for storage and back up for Mac? I have already transferred all my docs from i-rock to Mac in view of formating it but I need your advice first. If you think I should format it, how can I do so ? I do not see this option on Mac. Thank you in advance Hala
Macbook a1342 problem
Use a mouse to uninstall and then update the drivers for the trackpad. There may be an issue with driver corruption, or a device conflict causing the problem.
Jul 28, 2013 | Apple MacBook Mac Notebook
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
My webcam is not wking on my mac book pro ,it says device not connected
Thank you for contacting FixYa Support, I am glad to assist.
The best way to check if your iSight camera is working is to launch the built-in Mac OS X chat application, iChatAV and under Preferences check the video setting and see if the video will activate the built-in iSight camera.
As iChatAV is the defacto application to use and check video settings, if you cannot get the device to work, then you will more than likely need to take your Macbook in for at least a diagnostics to have your iSight camera checked.
This iSight is a built-in device, that if not working, as an internal device for your Macbook Pro, it can only be checked by a certified Mac technician.
If you are referring to an external web camera connected to your Macbook Pro, however, please feel free to reply back to this post and specify the model you have and we will be glad to assist you with that product.
Regards,
-Mactechtrainer
Sep 02, 2010 | Apple MacBook Pro Laptop Computer with...
I need to type a paper for class. how do i start? i have a laptop.
In order to type a paper for your class, on your Macbook, you would need a word processing application, in order to accomplish this. The most commonly used application, believe it or not,is Microsoft Office for Mac 2008 or the earlier version, 2008. However, if you don't have a copy of either and do are not moved to shell out several hundred dollars or more, I have another option for you.
Try Open Office for Mac. It is free and it does not take long to set up on your Mac.
Here are two key links for you to review for more info
FAQs about Open Office (Aqua) for Mac
Download Open Office for Mac OS X (Intel) Aqua
The word processing application you will need to use in Open office, is caller Writer" and it saves in all the formats that are readable in Microsoft Word for both the Mac and the PC.
If you have more questions on using this open source free software, please let me know. Always glad to help!
Regards,
-Mactechtrainer
Feb 14, 2010 | Apple MacBook Laptop Computer Mac...
I have dazzle dvd recorder for windows. I now use a Macbook!
Hi and welcome to Fixyah,
Dazzle DVD for windows can used only if you are windows system but for mac there is no particular driver or even the software to download. The product for MAC is Pinnacle video capture for mac which is the software is already included.
Jan 29, 2010 | Pinnacle Dazzle DVD Recorder
Macbook Pro airport extreme
You should only use Windows xp for running a program that is not yet available from Apple. There shouldn't be much reason to link to the net while in Windows. Also while in Windows you are wide open to any viruses that exist. Try getting your work done without getting on the net, then go back to your Apple format. There you are 99% free of viruses. … Still need to link onto the net let me know I will ask at our Apple Computer Club on Monday
Dale
May 10, 2008 | Apple MacBook Pro Laptop Computer with...
Macbook wont turn on
My computer used to do the same thing, I found out it was my motherboard / logic board and a hardrive combination. end cost $1500..so i bought a new Laptop. Go and get those things tested.
Feb 12, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Problems with macbook after downloading windows to it
Was Windows loaded on another partition? i.e. was it configured as a dual boot or is Windows running in a virtual mode (Boot Mac then start Windows while logged on in Mac).?
Jan 06, 2008 | Apple MacBook PC Notebook
Transfer to MacBook Pro from digital video camera
when you connect the camera to your mac via firewire, make sure you have an application open that will allow you to import the material.    The most common application being 'imovie'.
Dec 15, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
i-rocks External Hard Drive Enclosure - Silver Aluminum, USB 2.0, IR-9300 3.5in Drive Case Logo
81 people viewed this question
Top i-rocks Computers & Internet Experts
micky dee
Alan Rothery
Willem.
Willem.
Are you an i-rocks Computer and Internet Expert? Answer questions, earn points and help others
