Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Wireless router not detected by laptop
Well i've tried connecting my laptop to my wireless router but everytime i try my laptop does not detect any signal is there something wrong with my laptop? how do i fix this? i have a broadcom 802.11g Network Adapter
    Scholar:
  • 89 Answers
Hi!
First, make sure you know the SSID (name of your wireless network) and Network key (if your wireless router is secured). Also, make sure that the SSID broadcast of your laptop is enabled (this is an option in the router if they will broadcast the signal or not).
I assume that your laptop came with a built in Broadcom adapter. Depending on the brand of your laptop, there is always a wireless switch. You need to look for the wireless switch and turn it ON. For most laptops it's a sliding switch on either the side or front of the laptop. For some it's a combination key - like pressing FN + F2 at the same time.
For XP laptops, you can use the XP wireless utility located on the lower right side of your screen like this :
For some reason the XP utility cannot detect any signal and it's telling you that "Windows cannot configure this.. if you enable another utility, use that software to connect", that only means that there is another software in the computer that is running the wireless connection. You can go to Start > All Programs and look for that utility - you can start by searching a program like broadcom.
For Vista , look for this icon to connect:
I hope that helps.
Good luck and have a nice day!
Posted on Oct 02, 2008
Hi, I just replaced my old Dlink router with the N150 and I set it up following instructions on the enclosed cd. I can connect to the internet without any problem but our laptops and phones can't seem...
It's possible that you're just not broadcasting your SSID. Try going into the settings for your router by plugging directly into it with a laptop and visiting 192.168.1.1 (usually, might be different for your router). Put in the username/password (should be written on the pamphlet or be on the CD somewhere) and check your wireless settings to make sure that "Broadcast SSID" is checked. Also be sure that you've given it a unique name, and password protection is always recommended.
Jun 16, 2011 | D-Link Wireless N 150 Home Router 4Port...
May laptop won't connect to internet, my laptop is in good condition. i already reset my dlink wireless router but still don't connect to internet. The connectivity is ok. my laptop detects the router but...
Is the laptop detecting any wireless networks in the area? if yes then it means that the wireless card is ok if not make sure that the wireless is turned on on your laptop.
I the laptop detects wireless networks in the are then we should check the settings on your system or something that could be interfering with the wireless connection on your system,
what are the error/s when trying to connect wirelessly?
Tis can be multiple things regarding wireless, if the error is windows was unable to conenct to wireless evice then try recreating the wireless network on your laptop in network and sharing center if you have win7 on the laptop, network conenctions if you have XP.
I the laptop connects to the router but does not get internet acces then better check you routers network key if it is correct in your laptops settings, also check your IP address if it is correct if you IP starts with 169... then have a bad IP address on your laptop, go to the command prompt type ipconfig /release, then press enter, then type ipconfig /renew then enter to renew your ip address, hoping that the IP address changes it should begin with 192...
Feb 21, 2011 | D-Link DIR-655 Wireless Router
Wireless detection is faulty. It appears to detect some networks (usually low-signal ones), but it doesn't detect our own wireless network router which is a few feet away. I have another laptop and it...
Hi Thanks for your question.
You can try and change the channel that router is broadcasting on. This can be an issue sometimes. Change it to something popular like channel 4 or 8. I hope this was helpful. Good Luck
May 08, 2010 | Sony VGN-CR320E/P Notebook
Wireless not working
If you can detect the wireless network but you cannot connect to it, check the following:
1. Be sure that you are typing the correct network key (WEP, WPA-PSK).
2. If the wireless is unsecured, but still you can't connect to it, try to change the wireless channel.
3. Try to power cycle the router (disconnect the power cord from the wall socket for 5 minutes, then plug it back in).
4. Reboot the computer and try to turn off / on the WiFi of your laptop.
5. Reconfigure the router's wireless settings.
6. If same problem occur, contact the manufacturer and have them upgrade the firmware of your router.
If you cannot detect the wireless network, try the following:
1. Power cycle the router for 5 minutes.
2. Reboot the computer and try to turn off / on the WiFi of your laptop.
3. Change the angle of the router's antenna.
4. Change the wireless channel.
6. Upgrade the firmware of your router.
If nothing happens, then the router could be defective. Contact the manufacturer for RMA.
Apr 04, 2010 | AT&T 6850G Router (ALL07735)
My son is trying to connect his new Laptop a Packard Bell Easynote TJ65 (windows 7) to a Belkin 54G wirelessly. It detects the router but won't connect and the troubleshooter cannot detect a problem - any...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 12, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I have a DIR-615 router that I have no problem connecting my laptops with internal wireless. However, trying to connect my desktop with a DWL-G620 Wireless Adapter. It detect the network but will not...
The WPA key is the encryption key that is configured in the router's wireless settings and the wireless cards in the laptop and desktop needs to be configured with this encryption setting to allow the laptop and desktop computer to communicate with the router.
You can view the encryption settings in the router's wireless settings or on the laptop's wireless card settings and then apply these encryption settings to the desktop's wireless card (ie. the SSID and the WPA encryption).
Nov 15, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
Cannot connect via wireless network, router not being detected by laptop or ps3. I can connect to internet on desktop via modem through router. When trying to detect wireless network via laptop and ps3...
stupid question : is Wifi turned on ?
Go to your administration environment of your router ( typically : http://192.168.1.1 ) and check the config of the wireless settings
Aug 14, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Wireless connection problem
Hello There, are there any wireless computers that detects your router? If there is, most of the laptop computers has a built-in on/off (toggle) switch on the side to enable or disable the wireless card on your computer. Make sure it is "ON" then check if it will detect the wireless connection.
If it is a desktop, try to reboot the computer then check again. If none of the computers can detect your router, make sure that the wireless light on the router is lit up. You may also try changing the channel on the router.
Aug 03, 2008 | Airlink Computers & Internet
Laptop could not detect linksys on second day
Jatman,
Couple of things you can try here:
1) Connect your laptop (or another computer if possible) to the router using a network cable. You should then be able to see your configuration info. Make sure that the computer you are using to connect (wired) to the router is set up to use DHCP. Once in there, depending on what you find, you might be able to fix it yourself.
2) Factory reset the router and go through the setup options as if it were brand new.
Hope this helps.
May 18, 2008 | Linksys Wireless-G WRT54G Router
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
1,063 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
