Question about Toshiba Satellite A105-S4004 Notebook
Auto Shutdown I have started to have this problem with my laptop for last 2-3 days. The machine just automatically switches off and then powers back up again. I tried removing the battery and using the machine directly from power connection. However the problem persists. The machine typically goes off within 30-45 minutes of operations Please help
  • amolpawar Oct 02, 2008
    i checked that. fans are blowing. My computer is just about 13 months old and definately not abused like that :-)
    I am also checking for virus attack which might be causing this. Would appreciate if you can suggest some fix or is it that I would have to part with my laptop for few days to get it fixed throught the service centre.
  • conquest661 May 11, 2010
    You might have a cooling issue. Check your fans to see if they are blowing. How old is your computer? My old roomie had a similar issue but his computer was completely messed up(thrown around, possibly dropped).
    Genius:
  • Toshiba Master
  • 1,102 Answers
With ac power in
add/remove uninstall any prgrams you no longer need
then do a virus scan
then a disk defrag
Let me know if this solved
Posted on Feb 15, 2009
My laptop is automatic shutdon imidiatly
Have you check your fans if its working?
1. Check the fans if not working you must replace it or put some drop of machine oil.
2. Remove any dust blocking the airways from fans to heat sink.
3. Lastly check your software install there's might drivers conflict or infected by virus. This software issue might cause for the system to automatically shutdown
Jun 09, 2015 | Lenovo 3000 G530 Notebook
Automatic shutdown
Check the CPU Fan and make certain it is functional. Some computers do an auto-shutdown when the CPU reaches a certain heat ratio upon starting. Make sure the power conncetion is on firmly.
Jan 13, 2014 | HP Computers & Internet
Trying to fix 1990 Jeep Wrangler for our niece, Replaced starter and battery, nothing turns on when trying to start?
Not enough of a description of the problem. Does the car crank at all? How long was it sitting?
Sep 25, 2011 | 1990 Jeep Wrangler
Hi!!! I have an hp compaq cq 40 laptop.Frm sm days a problem persists wid it.whn its running normally ,all of a sudden its screen goes black...widin 1-2 mins its automatically shut down.Whn i restart it...
Check in the power options area of your operating system, and switch off hibernate and switch off sleep, this should prevent the machine powering down.
May 06, 2011 | Dell OptiPlex GX280 PC Desktop
My Dell Inspiron 1525 is shutting down at it own during working. From last 4 months I having this problem. during working, laptop shutdown automatically. And after that once I'll start again, its again...
there are 2 possibilities 1. cpu fan ventilation got blocked, so use you old tooth brush to clean it 2. the system is infected with virus. so user online virus toll to clean the virus any i recommend to us this link to clean the virus. it clean virus, spy ware & malware.
www.bitdefender.com/scanner/online/free.html.
i hope it will help you.
May 07, 2010 | Dell Inspiron 1525 Notebook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
My acer extensa 5620 laptop is not shutdown auto matically
if you want to shutdown your laptop automatically go to power option from control panel and from there you can schedule the time after using how many minute or hour you would like to automatically shutdown your laptop. Try it !! Good luck.
Aug 25, 2009 | Acer Extensa 5620-4020 Notebook PC
Sony Vaio Auto Shutdown... as if there was a power shortage
when your laptop begins to boot hit F8 to see if you can repair it. You may also have a virus on it that may have infected the boot sequence at start up or shutdown
May 12, 2009 | Sony VAIO VGN-CS115J/P Notebook
Unable to shutdown NEC versa S3300
It assume to be problem with BIOS, check out the Bios Power Setting and Boot Priority, by pressing DEL, ESC or Function key usually used.
And change them and then try.
2 method - try after unplug external devices and found which one is conflicting due to which it going to automatically start when you shutdown.
Thanks,
Ellin
Nov 04, 2008 | Computers & Internet
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
