Question about HP PSC 1350 All-In-One Thermal Printer
Check Carteidge Light Come Out without any change on hardware
I had used my 1350 printer for years, suddenly the message "Check Cartridges" light turn on. Please advise how to solve even I had re-install both cartridges several times already.
I have not change any cartridges recently and it worked fine in the past several months. I used the original 56/57 cartridges.
  • belladonna60 Feb 04, 2009
    I have just installed a new colour inkjet and now the 'Check print cartridge' is flashing.
    I have followed the instructions online for cleaning the said parts but not working.
    Up until installing this new cartridge I used the machine for a few days with only black ink, waiting to buy new colour one, could this have done this?
    Also, when I first turned it on with new cartridge it printed a test page with no problem.
    Desperate to get it going again!!
    New Friend:
  • 161 Answers
Sometimes you have to look through the settings and allign the cartidges.....check the options on the litle screen on the printer....itll be in settings....let me know what hapens
Posted on Oct 02, 2008
All lights flashing on HP psc 1350 printer
Resetting a Hp printer means switching off the machine, removing the cartridges, disconnecting the usb cable and the power chord, leave it off for few minutes then restarting it again without usb cable connected to it and without cartridges installed. You need to press the power button while it boots up. Leave it one for few minutes and again turn it off. Reinstall the cartridges and plug in the usb cable, again Power On the printer. That's all.
But there's another thing when you say all lights are blinking/flashing, there is chance that there's an internal faulty. Clean the cartridges contact point and the contact points on the printer. If possible, clean the printer thoroughly, including the waste ink tank. This will let you help find out the culprit.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
The cartridge error message seems stuck in memory
Please turn off the printer and disconnect the power chord and the usb cable, open the scanner door/backdoor, etc.. Remove the cartridges and clean cartridges contact points. Leave it for few minutes without any connection. Power on only with the power chord connected and without installing the cartridges and again leave it for few more minutes, switch it off. Reinstall and reconnect all the cables. Restart your system and boot up both the Pc and the printer simultaneously while you keep pressing the power button of the printer. Note that you have to use only the power button to switch the printer off or on. Good luck. Thank you for using FixYa.
Jun 05, 2010 | HP PSC 1210 All-In-One InkJet Printer
Will not print with print alligment continuous scroll with red light on. Says to remove tape from cartridge which did. Carteidge is new but remanufactured. Prints unrelated web pages not known
Are you using Dell Series 9 ink cartridges? Dell Series 9 ink cartridges have a sensor that cannot be reset. Article on refilling Dell ink cartridges
If these are Dell Series 9 ink cartridges, take them to the place of purchase for a replacement.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
The Check Your printer light keeps coming on. I
did you change the cartridges with O.E.M. or aftermarket? If with O.E.M inks then there is a problem with the waste ink container and it needs to b cleaned.. requires removal of the waste in station which is under the inks on the right side of the printer
Mar 31, 2010 | HP PSC 1350 All-In-One Thermal Printer
Check Printer Cartridge Error When Full!!
See instructions here to check the front panel, and reset the printer....etc. Other support options for your printer here.
Note that you're supposed to change cartridges with the printer turned ON, see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
Ink cartridges stuck after replacement
HP PSC 1350.
Very sensitive printer. Due to dust, the catrdges are getting stuck at right side. Please clean the steel roller where the catridges are rested. Clean it with nice cloth and if possible put 3-in-1 oil in that area only for the smooth flow of catridges in that steel stem or roller.
This might happen iif we are not installing the orignal and genuine catridges and there is a chance of ink gettng leaked onto the printer.
Kind advise is if the printer is old, please put an annual maintenace service contract with local authorized hp Printer Dealer which will solve your problem once for all.
have a nice and good working day.
Jul 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
Check paper tray check cartidge.
I have the 1350 all in one, and when I changed my cartridges I screwed up and replaced both at the same time, that was a no no as I found out. I kept getting the test printer and print example too. so what I had to do was Uninstall the printer and drivers, then reinstall them again, that worked.
Oct 28, 2008 | HP LaserJet 3015 All-In-One Printer
Canon iP4300 I normally refill my ink cartridges without any problems using ink from a Jettec kit. Suddenly the printer has said that I should replace one or more cartridges although they are all full....
You can only fill ink cartridges up to a maximum of 3 times, thereafter the chip on he cartridge need to be replaced. That's why u are getting that message my advice order a new cartridge.
Jun 10, 2008 | Office Equipment & Supplies
Printing light blue will full ink
its either the catridge head is bad or yr new ink isnt too good although its new it still can go bad. now try using menthylated spirit sucked in a tooth brush thats not too hard . use it to clean the inside of the cartridge head. that is those spots inside. cos atimes dirty could cause such problems. so try it out.
hope this helps
thanks
May 31, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
