LG 32LT7 television
Sometimes unable to change channel, increase volume, basically can't do anything except watch the channel that's tuned in at the time. CaN'T EVEN POWER OFF - Only solution is switching off and on at the mains
  • 3 more comments
  • Anonymous Oct 14, 2008
    Yep... the tv freezes more frequently every day!! the only solution at the moment is to switch off at the wall. But this also causes problems when recording another channel.. It will decide to only record 1m then cancel!
  • robpaul Oct 26, 2008
    Yes - an identical problem. I guess it is a software/firmware programming issue. I am not aware of whether or not there is anyway of updating this. I have had my TV for almost a year, so I would expect the problem to be sorted by now, but, maybe I am expecting too much.
  • Anonymous Dec 17, 2008
    Same problem here - Totally locking up with the only solution being to switch it off at the wall.
  • jerry_kochan Jan 19, 2009
    Yes same problem for my mother - she bought an LG 32LT7 at Christmas and I live in Dublin and she lives in Belfast and every night she is on the phone to me trying to solve the problems which are a daily occurrance. I am exasperated to find now that all of you guys have already found the very same problem!! The solution about switching it off at the socket and back on again is just not good enough! I am going to consult with a solicitor about consumer rights about this matter
    Jerry
  • Anonymous Mar 11, 2009
    Hi I have the same problem, mine is just a year old. I feel like putting a hammer through it and buying a decent tv. if anybody cures there,s please e-mail me.
    Mike
techman
  • 3130 Answers
SOURCE: Television
the liquid from the cleaner dripped down to the switch it sounds like and the only way to fix this if its not to late is to pull out the Printed curcuit board and clean the switches and the pcb in the front of the set and get all the liquid cleaner out and off the board. now you wanna clean the board with something without lubercante like a tuner wash from chemtronics or something like that. I've told peeps a million times , when you clean off a crt face apply the cleaner or spray on the cleaning cloth directly first. Never ever spray on a picture tube face as this will happen eventually if you do.. Good Luck
Posted on Apr 10, 2006
  • 81 Answers
SOURCE: UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Posted on Dec 15, 2006
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
SOURCE: codes for LG televisions
Try vizio codes
Posted on Jan 27, 2008
  • 3 Answers
SOURCE: Wharfedale LCD3210AF Television- Digital problems!
I would imagine that the Digital PCB is faulty.
Posted on Feb 12, 2008
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Mar 05, 2015 | LG 22LV2500 22" Inch 720p Widescreen LED...
I have a panasonic th42px60u my problem is that none of the controls work xcept the on and off volume is on but unable to increase or decrease the volume.
Hi Daniel,
May I know if the remote control is working fine except from the front panel's volume and channel button key?
Jdvillanueva
Nov 23, 2011 | Panasonic Televison & Video
Can not change channel on my Sanyo LCD TV
I have not solved it but, when I play the dvd player it seems to make everything else work....
Feb 14, 2009 | Sanyo Televison & Video
Unable to automatically scan for channels. menu button on remote does not work om my 1992 jc penney tv. No buttons on outside of tv except for the basic channel up/down and volume control. Recently...
To make it easy for you - you should have original remote.
Then through the menu look for channel set up then make sure you select cable or antenna then you do autosearch(sometimes called autoprogram).Unless the tuner is defective,you should be able to program withe the original remote.
Jul 19, 2008 | Televison & Video
Just got a lg 32lt7 tv and i cant tune in the digi channels all i get is not programmed?
u need to plug jst the antena in the back and then go on auto tuning
May 02, 2008 | LG Televison & Video
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Watching tv while recording onto vhs or dvd
This could be a couple of problems. I'm not trying to make you feel dumb or anything but sometimes people miss the obvious. Do you have an universal remote? How is your vct wired to your tv? Does your cable go to your vct or your tv first? These sound like silly questions but they are important.
Jun 02, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
