Question about Belkin (F5D7231-4) Wireless Router
Car device runs through speakers
Has turned itself off can not turn it on again
Took it back to the shop and they give me a new one.
It was a fuse
thanks
Posted on Oct 04, 2008
My speaker tower ITB123B will turn on, and will connect to bluetooth, but will NOT play music. Not from bluetooth and not from Radio. Is there a way to reset the device?
suggest following page 10
http://www.brandsmartusa.com/pdfs/manuals/20174760.pdf
and try to pair again with devices.
Had do you this on a jabra bluetooth speaker that was dropping the bluetooth and it fixed it ?
do not know how it .lost the pairing by itself but re doing the pairing fixed the jabra
Nov 07, 2016 | Cell Phones
AM FM radio Compact Disc player o.k. for 30 sec after start, then nothing. Fuses o.k.
Maybe a shorted speaker causing the power amplifier inside the radio to shut down or a speaker wire shorted to chassis and last the internal amplifier of the radio cd set faulty by itself... set volume to zero power it off take out the radio cd set; remove the speaker iso plug leaving the power plug only in and power it on if necesary turn again the volume down to zero and wait if it keeps turned on it a speaker problem if it shut itself off again then you go for a repair or a new one
Apr 23, 2016 | 2002 Toyota RAV4
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
How do i fix the amp on my radio?
When you turn the radio all the way up to max volume does the amp turn off ? you could have a short or a blowen speaker which is making the amp go into protection mode. i would disconnect all speakers then try one speaker by itself and see if you have full sound again... go through this process untill the sound stops again.
Jan 05, 2013 | 2008 GMC Envoy
I have a Sony STR-DE597 stereo and when I turned it on this morning, the receiver flashed PROTECT for about 5 seconds and shut off. I turned it back on just to have it flash PROTECT again and shut itself...
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Jan 14, 2011 | Audio Players & Recorders
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
My kenwood kfcw3011 stopped working. Amp indicator still on.
here is what you would do. the next time that your speakers cut out. leave everything running goto the speaker and slightly push on it. if the speaker starts to work again you have blown the coils loose and they are not making contact all of the time. you need to replace your speakers, or they could do more damage to your amp or head unit
if i have helped you in your issue, please leave a good rating. If you have further ?'s you can contact me at mega_muzik@yahoo.com
Oct 27, 2009 | Kenwood KFC-W3011 Car Subwoofer
Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Oct 01, 2009 | Sony CDX-M610 CD Player
It is flashing the word protect on the screen
You have a shorted speaker wire or a blown speaker. The unit is protecting itself from damage. Did you install it? if so, pull the deck and check your connections. If they all seem fine, disconnect one speaker at a time, and turn on the radio. Make sure the radio speaker wires are taped so they don't short and cause more damage. Test each speaker wire until you find which one is causing the problem. Now re-connect all the other speakers and test. Next, disconnect the speaker wire right at the speaker that's giving you a problem, tape it off, then re connect it to the receiver. now test again. If all is ok, you have a bad speaker, if not run a test wire from the radio to the possible bad speaker and test again. If the speaker plays, you know what the problem is, replace the bad wire. Most often it's a door speaker wire or a wire got pinched during installation and took a while to short. Hope this helps
May 24, 2009 | Kenwood KDC-MP332 CD Player
My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Mar 06, 2009 | Onkyo TX-SR606 Receiver
Belkin (F5D7231-4) Wireless Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
