FixYa.com
Tags:
HP Motherboard
USB Ports no longer work
By Jimmy NY - usenet poster
After loading a map for the game Battlefield 2, my computer crashed and started rebooting... I played the game again and after loading it crashed again, this time comming up with some "AMI" or something, menu. It had a check list saying that everything was "OK" and at the bottom it said hit F1 for Setup or F2 to continue with default settings. I hit F2 and everything was as normal except my USB mouse wasn't working. I plugged in an Ipod to test if it was the mouse and the Ipod did not work through the USB port either. All 4 ports don't work. The mouse worked on another computer.
Does anyone have any idea for what I should do? I already went to device manager and uninstalled all the USB devices and reinstalled them.
Thanks for any help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 30, 2006
Thanks for Trying (70)
Chandler
Chandler - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi, and welcome to TSF. In accepting the default settings, you disabled onboard USB support. You will need to enter the Bios again to fix this. At cold boot, press the "delete" key, that should get you the bios pages. Not sure which bios vendor provided your bios software, so I'll be a bit vague here. You are looking for "Onboard USB support" with an enable/disable prompt. You will want to change it to enabled. Select "Save and Exit" and follow the prompts to reboot. If you look while you're in there, there may be an "F" key entry for previous settings. You might try that. Be very careful what settings you change, as you can cause the system to not post, boot, or worse. All bios systems have descriptions of the settings within the page. Those are displayed as each item is selected
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP Compaq Motherboard HP (P2074-69003) Motherboard ASUS P5S800-VM Motherboard ASUS 865G (MBAS-P4P800VM) Motherboard ASUS P5P800 SE Motherboard ASUS P5B-E Motherboard ASUS P5B Deluxe/WiFi-AP LGA775 Core 2 Duo/ P965/ A (MB-P5BDLX) Motherboard
Can you Help with these Motherboards problems?
Motherboards
carte mere adequat ? mon...
j'ai boitier du mdele... Answer This...
Motherboards
My camera is not working,
My LG KU990 camera is not... Answer This...
Motherboards
MSI 745 Ultra onboard power led
Hey, you gave a great answer on... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
