Question about Maytag MDE2400AYW Neptune Electric Dryer
Maytag compact dryer low heat doesnot dry. works for hrs clothes still damp.
I have a compact may tag dryer that I purchased recently used, when I tried the heat is low . It goes on for few hrs and still the clothes are damp. The back of the machine is extremely hot alo the drum feel very hot, but inside the machine low heat not enough to dry the clothes. Any suggestions.
Fred
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
Clothes coming out wrinkled after drying
Is the dryer heating? If so try using dryer sheets and allow a bit more on the timer, if the clothes are still damp..If the dryer is running properly I see no other way to solve this.
Jun 07, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag bravos dryer is not drying?
sounds like your heating element is going bad
Jun 17, 2012 | Maytag Dryers
Yesterday i was drying clothes and then all of a sudden it is running but not putting heat out...when it finishes the clothes are not wet not really damp but not dry
Heating element needs to be replace. It made by several sections to produce heat. some section are bad so heating didn't come on with its full capacity.
Apr 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
MY MAYTAG DRYER PYE2300AYW TAKES 2 CYCLES TO DRY THE CLOTHES
I would imagine your vent duct needs cleaning. We recently had the same problem and a duct cleaning kit from Lowes (about $40) took us from what felt like 'reasonable' airflow outside to "oh-my-gosh, what a difference!!", and left an astonishing pile of nasty, damp lint on the ground out there...
There's a good chance the same treatment would do the same for you. Hope it helps!
Nov 02, 2009 | Maytag PYE2300AY Electric Dryer
Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will heat and does dry some but when it moves to the less dry the dial does not move and the dryer does not heat
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Oct 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How does may tag intelli dry work? what is the difference between less and more heat setting
there is a sensor inside the door to the right it actually "feels" the dampness of the clothes across the two strips on the sensor, if you close a wet washcloth in the door so that it hits the sensor you will see that it will show as wet and it will run longer.
if nothing in the load hits the sensor the sensor will call it dry and the load will finish, larger loads work better with sensor dry small loads not so much. if there is alot of trouble try using the timed dry cycle.
Sep 03, 2009 | Maytag PYE2300AY Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not drying after 70 minutes
your dryer could possibly have 2 heating elements and 1 has burned out, I had that problem once.
Apr 19, 2009 | Dryers
Maytag MDE2400AYW Neptune Electric Dryer Logo
377 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
