Question about Sony Playstation 3 (PS3) Console
PS3 i have my ps3 powered on and i have the tv on the video channel. it seems as if it want to come on but it doesnt some white lines just scroll up a black screen
    Scholar:
  • 125 Answers
What kind of TV is it? if its an HDTV usually the ps3 just scans that by itself and it will ask you in the beginning before it does anything else. If its just a regular TV make your that the cables are connected on the right place maybe something is wrong with your television. Let me know how it works out.
Posted on Oct 02, 2008
PS3 Connection problem with this particular tv model.
connect PS3 to Tv with RCA cables (white,red,yellow) go to display settings change to HDMI, Tv should go black remove RCA cables and connect with HDMI.
Jan 10, 2018 | Samsung LE22B450 22 in. HD-Ready LCD TV
How do i use the ps3 on a normal tv
If the "normal" tv has the Composite(rca) inputs yellow red and white. the PS3 will work on that if it doesnt you can buy an RF mudulater for under $20 at Walmart. When you do hook it up to those input you next have switch the channel to the input. Also the video settings on the PS3 have to be set for 480i no other setting works on a "normal" tv
Dec 14, 2010 | Video Game Consoles & Games
I AM TRYING TO RECONNECT MY PS3 ON MY LCD TV AFTER 2 WEEK BEEING DISCONNECTED AND IT DOESNT SEEM TO WORK THREW HDMI CABLE! IT SAYS THAT HDMI CABLE WAS DETECTED BUT WHEN I AM ON HDMI CHANNEL ON TV THERE IS...
I think maybe the following steps might help you out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont broadcast cast right.
Try holding down the power button for 2 beeps. This will reset the PS3 video to standard mode.
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
I plug up the ps3 and when i hit the power button it beeps
This can sometimes occur when the system is hooked into a vcr or tv through the audio video cables. Make sure to check the channel for output some tv's have channel 3 and the vcr/dvd I have to turn it on and select L1 for line 1 input. Also I have experienced the actual audio video cable you get with the PS3 sometimes goes bad, so I had to get a new one. Another reason it may be just beeping is the software update did not complete and the system shut down or power outage occurs, if the above answers don't work check sony's website for more information how to fix a corrupt system update.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
PS3 image keeps scrolling and is in black and white
I am an Australian ( 240v) and I took my PS3 to the Caribbean (110v - same as the US) and it worked fine as far as power concerned. However as I had the PS3 set to work on my TV back home (PAL) when I took it over there & plugged it in (NTSC) I had a similar problem. I fixed it like this: when the PS3 is turned off hold down the power button for 15-30 seconds it will reset the PS3's settings to defult and it should work on the system that it's connected to. Hope it helps
Jul 02, 2009 | Sony PlayStation® 3 (80GB) Console
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
I've had my 80G PS3 for less than 1 month and I am having a major problem. Everything was working fine. I occassionally turned it off directly from the back. 99% of the time I shut it down correctly. I...
Hold your ps3 power button. It will scroll to different video settings. I believe there are 3 different video settings. I believe each beep is a different video setting
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
My PS3 only works on my Plasma tv's HDMI channel. None of my other tv's have this HDMI channel. Why doesnt my PS3 work on any other channels or my other tv's? Could anyone help out with that?
When you have the ps3 hooked up through av cables on crt tv not hdmi. Continue to hold power until the console beeps again and this will reset which audio video output resolution back down so it can be seen and heard. Hope this helpes.
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
Lines on the screen
Try holding the power button on the ps3 for about 10seconds. It should beep as it normally would turning on, carry on holding the button until it restarts. This should restart the ps3 in standard mode so that it can be viewed via rca/scart connection.
Jun 07, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
