Question about Brother MFC-8440 All-In-One Laser Printer
Toner drive won't turn new toner cartridge
I have tried two new high capacity toner cartridges and the drive won't turn them. It clicks and I believe it is designed to slip and click instead of burning out the motor. The gears don' t appear to be stripped. Are the high capacity cartridges harder to turn than the lower capacity ones with less ink? The machine cycles thru without a problem without a cartridge installed. I had no problem with the OEM low capacity cartridge. Thank you.
Peter
I was able to find and repair the problem. A shaft with shoulders fits into a thimble which engages and drives the cartridge. The shoulders wore away or were defective. The clicking I heard was the shoulders trying to engage the thimble. I had to purchase a frame L drive unit which is expensive and deep in the machine. It was beyond my expertise but I can only say I was lucky and everything went back together without too many left over screws and it works well. I was able to get the service manual but even with that the repair was sketchy. I had to buy quite a large part in order to replace that small defective part. Compared with the cost of a comparable replacement machine the repair was worth it though.
Posted on Oct 16, 2008
    Problem Solver:
  • 5 Answers
The TN-570's work equally well as the 540's so that's not the problem.  The ink is incredibly fluid in its dry powder form and wouldn't make turning with the torque ratio in the machine even notice a difference. Double check that you have the right number replacements and if refilled from an outside source I'd bet its either wrong ones or bad copies.  Best to you.
Posted on Oct 15, 2008
2300dl toner problems
Unfortunalely printers and there drivers estimate toner life buy counting the amount of dots draws on the pages. Say a cartridge is rated for 3000000 dots when new, the printer will know after printing 1500000 dots that the cartridge is about half full. If you replace a cartridge the printer will assume it's new as the ID tag will be different from the last cartridge. There really isn't any way of modifying or specifying the age of a cartridge. You will just have to keep using it until you start seeing drop outs on the page, then you will know it is almost empty. Shaking it a few times will usualy help stretch the life of a cartridge.
Jul 04, 2008 | Konica Minolta magicolor 2300DL Laser...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
May 01, 2009 | Xerox Phaserâ„¢ 6180DN Laser Printer
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Toner Capacity
This does not need to be done. there is a chip/fuse built into the toner that basically tells the printer how many paes that toner has printed in its life time. no adjustment is needed it is all automatic
May 31, 2008 | Epson AcuLaser C900 Printer
Brother MFC-8440 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
