Question about Dell Dimension 2400 PC Desktop
Hey. I did what you said and downloaded the diagnostic. Im not exactly sure how to use it. what exactly do i put on a cd? also im not sure what you meant by ESD... :) plz respond tryin to figure this out! BTW THANX!!!!!
  • 781 Answers
Get a program to burn cd's... nero or magic iso (paid or hacked versions are needed)
with the executable file you downloaded you create either a boot floopy disk or an iso file
since it sounds you're trying to use a cd as your booting option you need to create the iso file with executable file (.exe file) and with nero, or magiciso you can burn a bootable cd from the .iso file (image file)
here are some instructions and a program you can download for free to burn an .iso image into a cd
http://www.petri.co.il/how_to_write_iso_files_to_cd.htm
once you have your floppy booting disk or your cd burnt and ready don't forget to change the booting order in your bios to have the floppy disk or the cd as the first option when booting your computer...(so the computer tries to boot from that device instead of your hdd) you need to read you computer documentation on how to go into the bios when you first start... usually the bios first screen message will tell you to press and f key to go into setup or something like that.. once you go there... go into the boot menu with the arrow keys and change the booting order
this will give you an idea on how to change the booting order
http://www.whitecanyon.com/how-to-change-boot-order.php
ESD is electroc-static discharge... as you move and touch things your body gets electrical charge.. when you touch stuff you discharge the electrical currrent that you built up and if you're accidentaly discharging this current on an object that can't handle it you may be frying that object...
it's like when you're out in the cold and dry outdoor.. you come into the house and you touch something metallic.. you get shocked... is the same.. what happens is with components inside your computer, you gotta be extra-careful because with discharges that you may not even feel you may end up frying a component and you may not even know it, until the motherboard starts acting up on you intermittently or with no apparent no reason.
general rule.. when opening the case or dealing with components inside your computer ground yourself with a antiestatic wrist band or if you don't have one at least touch your power supply unit before touching anything else inside your computer. (that's how your ground yourself)
good luck
Posted on Oct 04, 2008
I havent used the fax machine in quite sometime<<< i must be doing something wrong... im able to receive faxs but cannot send them, im sure im prolly doing something wrong can u give...
Hey!!The best and fastest way is to put in your documents in the ADF(automatic Document Feeder)Put the machine on fax,Dail your fax number and press the BLACK start button.Good Luck!!
Nov 05, 2010 | Canon MX310 Office All-In-One Printer
Is that possible to install Manx TT on Windows XP? Any Solution.>?
hey there welcome to fixya
im sure its possible put in the cd and see what happens please remember to rate this slution
regards
magical ink
Jun 23, 2010 | Sega Manx TT Superbike for Windows
Xbox 360 downloaded music
Im pretty sure its bec of the type of cd, try using another type. Hope i was of help
Jul 27, 2009 | Video Game Consoles & Games
FILE TRANSFER WITH BROKEN PHONE
If you have had a M2 in it and saved your stuff on it all you have to do is get the little card readers or whatever they are called and stick it into your computer and download away.
Oct 22, 2008 | Cell Phones
Fuel filter
On your car, it is located under the car, on the driver's side frame rail. The easiest way to find it is to get the new one first, so you'll know exactly what you're looking for.
Make sure to discharge the fuel pressure BEFORE you start!
Aug 19, 2008 | 1997 Chevrolet Monte Carlo
My comp doesnt have a cd rom so I cant down load the software to put my pic on my comp. Im looking for a site to download the software with out useing the cd rom
Hey there boydestin, the information you need can be found here:
http://www.samsung.com/us/support/download/supportDown.do?group=camerascamcorders&type=cameras&subtype=sseries&model_nm=SAMSUNG%20S73&language=&cate_type=all&dType=D&mType=SW&vType=R&prd_ia_cd=04010300&disp_nm=S730
If the link does not work just copy and paste. The file you need is there as a download that you can put directly on your computer. There are also other things you might like to download there. Good Luck!
Mar 13, 2008 | Samsung Digimax S730 Digital Camera
LOST CD
go to this site.
www.driverguide.com here you must register (free registration)
and you find it.
Sergio
Jan 11, 2008 | Philips SPC 200NC Webcam
Instalation of a gm-x622
Trim God Hey Kell77. Go to this site if you have not already tried this. I found your amp but no manual. http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069937_36965,00.html If that does not help, Google "Pioneer" and check out each site till you get what you need.I found the manual on this site,but it costs 9 bucks. Maybe you can get it for free if you search around a bit.http://www.tradebit.com/filedetail.php/824757. If you can't find a manual for your exact amp, download a manual for the same model type that is less or more powerful than yours. The wiring diagram for all the GM-X models might be the same. Just use your judgement and caution when wiring it up.
Oct 02, 2007 | Pioneer GM-X722 Car Audio Amplifier
Dell Dimension 2400 PC Desktop Logo
81 people viewed this question
Alun Cox
