Question about Mitsubishi WS-65807 65" Rear Projection Television
Won't power on...
We turned off our TV last night and went to turn it on this AM and the green power light will flash for a few seconds and then automatically power off. It was stated in previous answers to check the PC board (which I have no idea what that is) or to contact a repairman. First, this TV was left by the landlord who didn't want it so I doubt he will want to pay for any repairs and I can't afford to repair it either. Any other troubleshooting I could do on my own to figure out what the problem is or how to fix it myself? Thanks! Jenny When I push the power on button, WS-65807 TV it makes a sound like it is going to power on, however there is no picture or sound. The green light (labeled timer) lights up - does NOT flash. Everything I have read so far points to some kind of convergence IC's (whatever that is) or a circuit protector or pico fuse. Could this be an easy fix or an expensive replacement not worth fixing?
    President:
  • 1,952 Answers
If not: Then you may have a power problem; either the outlet you are using is not active or the power cord is defective (not uncommon). Use a lamp to test the outlet the tv is plugged into. Then wiggle the cord to see if the molded ends have come open circuited inside.
Posted on Nov 02, 2008
  • 1,512 Answers
Hi Jenny,
Sorry to be the bearer of bad new to you, television repair is not as easy as the "internet" would have you believe. You will hear most people try and tell you it is an easy fix with convergence IC's requiring replacement. The truth is, even if that were the problem, it is not a job I would recommend that you attempt unless you have all the required tools for desoldering, and replacing parts, and then competency with soldering to complete the job.
If there is no sound or picture at all, it is more likely to be a power supply failure, or worse case something else thats failed shutting the power supply down. Without having previous experience with repairs to projection TV, it could prove to be a can of worms for you to attempt to do any sort of diagnosis.
Sorry to be the bearer of bad news, but from my experience, the best approach you can follow is this. I suggest you get a tech out to give you a quote for repairs before you attempt to do anything yourself, just in case your efforts create additional problems that will cause dramas. Of course if you dont want to spend anything at all towards fixing it, I suggest you should perhaps look at a new LCD set. They have come down in price so much over the years, and even after fixing this unit, you still have an 8 year old set, that may well cost you more money in the future to fix.
If you think that this is good advice, the please accept my post:)
regards
robotek
  • 171 Answers
I will first start out by saying, it is very important that you have some soldering experience working on solid state printed circuit boards and that you know that too much heat from the soldering iron will most likely ruin the pc (printed circuit) board. If this happens, it can be a very difficult repair. The boards are no longer available for these sets from Mitsubishi so I cannot stress enough, if you have no soldering experience, let a pro assist you in this repair. One more very important thing to remember and NOT DO!! If the convergence is way out or cannot be adjusted by the customer controls, do not go into the service menu and try to adjust the convergence. It will only make it very difficult for you to adjust the set after it has been repaired. The service menu adjustments are to make MINOR drifting alignments, as over time, the adjustments may drift a bit due to part tolerance changing. I am using the adobe reader eight (8). If the page numbers do not match up as I have explained, then you will need to upgrade to the newer version eight (8). The service manual Is available for a free download at http://www.techlore.com/group/2/list_downloads
Next, let’s get together the equipment you will need to work on this puppy. You will need a # 2 Phillips screwdriver to first remove the backboard in the rear of the TV set as described on page 10 of the service manual. Next, you will need a small soldering iron with a desoldering bulb to remove the solder on the pins of the IC’s. I recommend an inexpensive one from Radio Shack. It is a 45 watt type, item number 64-2060. You can see it here http://www.radioshack.com/sm-buy-the-45-watt-desoldering-iron-on-http-wwwradioshackcom--pi-2062731.html. Next, you will need a small amount of rosin core solder to re-solder back in the new convergence IC’s. You can get that at Radio Shack also. The item number is 64-017, and you can see that here http://www.radioshack.com/product/index.jsp?productId=2062719&cp=&sr=1&origkw=rosin+core+solder&kw=rosin+core+solder&parentPage=search Next, you will need what’s called heat sink compound or thermal paste. The item number is number is 55014135 and can be seen here http://www.radioshack.com/product/index.jsp?productId=2526910&cp=&sr=1&origkw=thermal+paste&kw=thermal+paste&parentPage=search. You also might wish to pick up a small amount of solder braid to assist you in cleaning up the area around the un-soldered pins of the convergence IC after you remove it. It is very important to make sure you have no solder splashes or bits of solder lying around or across any of the adjacent circuits. Now we need to get ONE (1) STK393-110 convergence Amp IC’s. I recommend getting those from here http://www.electronic-repair-kits.com/STK393-110.html. The reason I recommend this distributor, I have ordered many of IC’s, a lot for a lot less money, but they are not original Sanyo IC’s. Yes, these IC’s in this Mitsubishi set is made by Sanyo. A lot of the less expensive IC’s are not original and the aftermarket types made in China. I have heard also that some parts distributors buy factory reject IC’s and sell them as good original IC’s. That being said, it is up to you if you want to be back into your set several months down the road because of another convergence problem. Play it safe, and stay original. . You will also need a small multimeter or DMM ( digital multimeter) and know how to use it. You can get the five (5) amp pico fuses if you need them from http://www.bluestar-online.com/5_AMP_PICO_p/5%20amp%20pico%20fuse.htm.
Next, is a very important step. MAKE SURE THE TV SET IS UNPLUGGED FROM THE WALL SOCKET!! This may seem a bit redundant, but I cannot count how many times I have seen technicians rush into a job and forget to unplug a set from the wall. Now let’s get into the set. First remove the back board by removing 20 or 21 screws from the backboard of this set. This is described on page 10 of the service manual. Next, remove the left and right speaker grill covers as well as the center part of the TV set in the front. These simply pull off so do not be afraid to pull on them a little, side to side till they come off. Now take off the front board by removing six (6) screws. This is all on page nine (9) of the service manual. Now, remove three (3) screws securing the entire chassis in the rear of the set as described on page 15 of the service manual. Next, unclip the two (2) chassis locks in the front of the TV set as the locks are shown on the front of the chassis on page 16 of the service manual. Now, slide the chassis out toward the rear of the unit and slide upwards to access the bottom of the printed circuit board.
Posted on Oct 02, 2008
  • Todd Gale
    Todd Gale Oct 02, 2008
    Now, let’s look at page 16 towards the bottom of the page. There right in the middle of the power board, the board in the middle part of the chassis, notice the large metal block with fins on it. On that block, which is called a heat sink, is a line that says IC8C01 & IC8C02 conv. Outputs. That is a mistake in this service manual. There is only one (1) Conv. output IC in this set and it is marked IC8C01. Now you want to first locate the two (2) pico fuses on the main power supply board. As if one or more of these are not bad, your convergence IC is most likely not the problem with the set. This is not always the case, as maybe the IC opened up and not shorted, therefore blowing out the fuses. I have not seen this condition too many times though. The fuse are marked ON THE BOARD, as F9A04 and F9A05. They are located next to or near a large transformer labeled on the board as T9A50.They do not look like regular glass fuse but more like resistors. Measure for a short or full continuity across both of them. If one or both are bad, DO NOT simply replace them, the IC is bad, and replacing them will cause further power supply damage. Fuses do not blow in this set unless there is a problem. . My experience has been, if a fuse or two are bad, find out why it blew. These are 5 amp pico fuses. And can be ordered from the link that I have posted above. These pico fuses control the plus and the minus 24 volts to the convergence IC. Also be sure to check the resistance of several feedback resistors. They are labeled on the PC board as R8C05, R8C06, R8C13, R8C14, R8C21, R8C22, R8C29, R8C30, R8C37, R8C38, R8C45, and R8C46. These resistors are flameproof and are 3.9 ohm resistors@ two (2) watts. The other resistors in this convergence circuit that sometimes will burn up are labeled on the board as, R8C07, R8C15, R8C23, R8C31, R8C39, and R8C47. These resistors are also the flameproof type. The values of these resistors are 150 ohms @ three (3) watts. Also, if you have the plus and minus 24 volts on the power supply but not on the convergence IC pins numbers 10, 12, 13, 15, 16, and 18, check the two coils labels on the board as L8C01 and L8C02. If one or more of these cols are bad, replace C8C05, and C8C03. They are 1000uf@50 volts. Next thing you want to do is to carefully remove all of the solder on all of the pins on the convergence output IC. Make sure each pin is free to move around inside of the hole. Now, unscrew the two screws that attach the IC to the heat sink. Now remove the IC from the printed circuit board and the heat sink. Sometimes the silicone thermal paste dries up and you have to pry off the IC, but it will pop off. Next, do your best to scrap off any large amount or clumps of old thermal paste off of the heat sink. It does not have to be shiny clean though. Now, make sure all of the pins of the new IC are all lines up, and straight. It makes the re-install easier. Now, apply a liberal coating on the back side of the new IC, not too much as it will get all over the place. Just enough to coat the back side of the new IC. Now, insert the IC back into the board and making sure all of the IC pins go straight into the holes and do not bend, or short out against each other. Next, carefully solder each pin at a time on the board, watching and being careful not to short or bridge any solder on to the adjacent pins or circuit pads. Double, no triple check your soldering job. Clean up any excessive solder flux with a cue tip and alcohol. Reinstall the chassis and make sure that any plugs you disconnected are back into its proper connector and double check every plug and connector by hand, not by sight, for loose or shifted connections. Now, plug in the set and see if you did your job correctly. If the set will not come on, check the pico fuses again. If one or more are bad again, the IC is bad, or there is a short across one of the pins. If the set comes on, but the convergence is way out, you may have a bad feedback resistor or two. If you messed with the convergence before you replaced the IC, you may need a pro to assist you in making the final convergence adjustments. Good luck and be carefull!
    Master:
  • 726 Answers
There is a fuse inside the tv but mostly sounds like the power supply box inside has died
and yes it can be the converyance ic board inside it controls pic and sound and if that died its expensive if you dont no how to do it
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to check the power supply if it is ok try to use tester
or may be there a lost of connection to the board!!!
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
I have a Samsung plasma over 5 years old. power
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
Nov 02, 2009 | Samsung HPN4239 42 in. Plasma HDTV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Won't power on...
Unplug the TV for a minute then plug it in while observing the power light. If the light flashes three times then the standby power supply is OK.
If the standby power supply is OK, a diagnostic code can be read from the green power light by counting the flashes. Press the power button once (this sets the diagnostic code). Press and hold the INPUT and MENU buttons on the fron panel for 5 seconds then release. The green light flash a two digit code (x flashes, followed by a pause, then y flashes). If it flashes a 2-2 code then a short circuit has been detected in the switched power supply. It would normally flash a 1-2 code for "no problem detected".
If a 2-2 code is read, check for blown pico fuses on the POWER circuit board. If the FA904 or FA905 fuses are blown then most likely at least one of the two convergence driver ICs are bad. It seems like this is the most common failure. I replaced these fuses and ICs in my TV. The parts cost me $50, but it required extensive disassembly, PC board desoldering & resoldering, and reassembly. If you can resolder circuits on a PC board then you can probably fix it yourself, otherwise call a repair person.
Sep 07, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
283 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
