Question about Philips 42PF9630A 42 in. Plasma Television
Set dosen't power on/off.
Set will not power on. When powered up greel light is followed shortly by sound, then a click sound. The green light turns to red and flashes 4 times then pauses and flashes 4 more times. This continues until I unplug the set. It dosen't power off with the power on/off switch.
  • okerlund87 Oct 02, 2008
    same problem
I have a 50" plasma Phillips taht does the exact same thing... same solution??
Posted on Oct 08, 2008
  • 138 Answers
Replace the small signal board 310432842611.
Posted on Oct 06, 2008
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Akai model ws-p28ntf-sf-d-gb (s) tv/dvd combo
Disconnect it from power cable 30 mins, see if this reset works, for the rest sounds like you have a problem with the power unit.
Mar 28, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
No power jbl speaker
that was mean has shorted line, check for shorted amplifier ic.that was mounted in big heat sink.
Aug 16, 2012 | Audio Players & Recorders
KP-51WS510 blinking light but no picture at all. Audible click like usual followed by another click sound shortly after.
THE click is the relay on the power board coming on and then going off---red power light should blink a error code---when set shuts off (second click) watch the power light and count the blinks.
Let me know what you find.
SD TECH
Jul 28, 2010 | Sony KP-51WS510 51" Rear Projection...
My canon i850 printer head will not move. When I turn the printer on I get a green light followed by 5 amber lights then it alternates 1 long green followed by a short amber,short green, short amber and...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2009 | Canon i850 InkJet Photo Printer
No picture, no sound, green LCD light
Wow another Toshiba bites the dust! I am telling you from my expertise on toshiba that these people are having more problems then there worth to fix this your looking at $250 bucks justi n parts alone we not even talking labor. I worked on more TV's then computers now days. I would recommend not even trying to repare this unit. Find a sony and buy it. You be glad you did!
May 25, 2009 | Toshiba 50HP66 50 in. Plasma Television
Tv will not turn on, makes clicking noise as the green light blin
clicking = power supply not coming up
bad power supply, or bad (shorted) part causing power supply to not come up
with a volt meter we can troubleshoot
Feb 05, 2009 | Akai LCT2715 27 in. LCD Television
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Tv wont turn on
The green light indicates that it is getting power from the outlet ok.
The clicking is the power relay trying to turn it on but there is an internal fault forcing it to shutdown. You either have a power supply problem, horizontal output transistor (HOT) is shorted or a bad flyback transformer. In any case it can most likely be repaired by a qualified technitian. If it is the flyback it may be expensive.
Mar 10, 2008 | RCA F32650 32" TV
Blinking red light
If your Sony TV is hooked up to a good signal and is set up correctly, but only clicks and has no picture or sound, and even the menu will not show up on the screen, then it means that the main power supply has stopped working. I usually find that a small crack in the solder joint of the horizontal drive transformer or a shorted flyback will cause the large horizontal output transistor to short out, and this shorts out the switching transistors in the main power supply which then causes the Sony 0.1 ohm fuse resistor to open up. I have also seen power surges or power failures (brown-outs) cause the switching transistors to short out. In any case, the set absolutely should be serviced by someone experienced in repairing Sony TV's.
Aug 05, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 42PF9630A 42 in. Plasma Television Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
