Cannot view windows setup screen
I just posted the same problem before but cant find appropriate solution.. pls help! An error : "insert system disk and enter" appear when im trying to boot from cdrom. and while im trying to backup my pc data using the express recovery2 feature (installed in my driver cd that came with my computer package), the error "cannot install windows operating system in HDD PARTITION" appear.. All i want is to reformat my computer. is there any solution so i can proceed smoothly to reformatting? pls. help
  • 48 Answers
First you must configure your bios..set the first boot with cd rom and disable the HDD.
then exit. and insert your installer for windows. and setup will follow.. hope this would help.
Posted on Oct 02, 2008
MY LAPTOP NX6120 IS SHOWING non-system disk or disk error replace and strike any key when ready WHAT CAN WE DO
If F8 does not give you any option to repair the system, set the bios to boot from the DVD rom and insert your Windows disc choosing repair when prompted.
Feb 12, 2015 | Computers & Internet
Help how to format lenovo ideapad s300 in windows 7
If you want to format your entire hard drive (and reinstall windows) You'll need to insert the appropriate windows disk. If you want to reinstall 7, insert your windows 7 disk and boot off of the disk (When booting, it should start by showing a screen that says "Press any key to boot from CD..." and you can just press a key on your keyboard. From there, follow the on screen instuctions. When you get to the drive partitioning step, select your hard drive and partition you want to format. You can delete the partition you have and make a new one if you want to totally clean the computer (WARNING: This will literally delete everything on your computer. Everything). From there you continue and finish the setup (it may run for a while). And you have a fesh new hard drive and operating system install.
Sep 12, 2013 | Lenovo IdeaPad S300 Laptop Computer -...
Windows XP download
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
May 13, 2012 | Microsoft Windows XP Professional With...
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
Acer 5534 will not boot up....tried recovery disk....but nothing......error message PXE-E61-media test failure..........no bootable device
Hello:
Your Acer laptop is not detecting a bootable device, for sure your hard disk is:
1.- Malfunctioning and has lost its master boot record.
2.- It can be ruined and must be replaced.
In the first case, primary and recovery partition are bad, as you mention the recovery process failed (ctrl +F11). First, press F2 during POST, when "a enter Setup message" is prompted on the bottom of screen to check if the hard disk is listed on the Main BIOS properties. If detected, the hard disk can be recovered booting from DVD-ROM. In the BIOS setup utility, you need to select boot from de DVD-RW. Insert Windows 7 setup disk and it will check for possible boot errors, choose repair when prompted. Follow the instructions. The system will restart.
If the hard disk was not detected in BIOS properties, you should ask Acer for guarantee.
You may review this link for further information: http://www.acerlaptoprepairs.info/aspire-5534/
I hope this helps. Thanks
Jan 30, 2011 | Acer Computers & Internet
How to install winxp to laptop dell inspiron 910. dell inspiron 910 no hdd but 8gb flash drive
A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:
313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup program To perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
Post back if it is not working we will be happy to help you.
Thank you.
Cheers!!!
Jan 09, 2011 | Dell Inspiron Mini 10 Notebook
Gateway MX6455 - AMD Turion 2.0Gb with 1Gb Ram Stops working and goes to black screen after POST. Will not boot into windows. The more I try re-booting, the faster it stops.
If you recently installed and any new program it could be a corrupt driver. Boot to safe mode by hitting F8 and delete it. If you didn't, you will have to remove drivers individually. Failing hardrive is another culprit.
Mar 04, 2010 | Computers & Internet
Operating system not found
You can't insert a Hard drive from another PC because when it was installed on the old PC it was setup to work with the hardware for that particular computer.
You will need to reinstall a fresh copy of windows on it to make it work with the new PC it's in.Boot from CD run windows setup, format the drive then do a fresh install.
This should fix the problem, if you have any new info or need further help with any of that post back. Thank you for choosing Fixya!
May 27, 2009 | Microsoft Windows XP Professional
How to install windows xp
Enter BIOS Set CD rom drive to first bootInsert your CD reboot
folow the on screen instructions be patient, it may take up to an hour,  and then two houers to install drivers,
-> if you want me to find the drivers for you, plz state your computer name and model.
regards /Teis
Jan 11, 2009 | Microsoft Streets and Trips 2008 for PC
PCG=TR3A
When you formatted the hard disk of the laptop, the appropriate drivers were also erased. It is therefore necessary to reinstall the drivers and specifically for your concern, the VGA Display. Pls click here to view available downloads for the Sony PCG-TR3A. You would be particularly interested with the Intel Graphics Controller Driver.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Sony PCG-TR3A Notebook
Computers & Internet Logo
426 people viewed this question
David Payne
David Payne
