HP Motherboard
Problem for HP (D7580-60003) Motherboard
Troubleshooting with a multimeter
By pandamama - usenet poster
how to: Troubleshooting with a multimeter
Same Problem
Jan 31, 2008
-   INSTALATION FRONT PANEL COMPONENT-   BETO1122
Best Solution
posted on Mar 02, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Testing the Motherboard for open circuit...
Remove the CPU from motherboard socket before doing this test.
Refer to ATX 20-pin connector pinout chart for GND pin locations. Use PSU's 20-pin connector to familiarize yourself with the board's connector. Only test the GND pins, the multimeter's internal voltage may damage a component connected to the other pins.
3. Keeping one probe on chasis, check GND pins 3,5,7,13,15,16,17 should have the zero reading, any other value suspect a fault-check board is properly installed and repeat test.
If still non-zero remove board and test GND pins again, with one probe touching the metal ring at a mounting hole, if still non-zero then motherboard faulty-replace it with another board.
gate way bois
Solution #2
posted on May 30, 2006
Helpful)
2Pansy
Rank: Apprentice
Rating: 0%, 0 votes
NOTE: This testing applies only to the standard ATX PSU, it does not apply to proprietary PSU's (ie: older Dell's ) which use a different pinout arrangement for their ATX connectors (non-standard).
20 and 24-Pin Connectors: The 24-Pin connector has an additional 4 pins attached to one end of the connector. The top 20-Pin section is electrically identical to the original 20-Pin ATX connector. Due to the additional connections the numbering sequence changes, so if you have a 24-Pin connection then make that adjustment when comparing any numbers shown below. (Refer to the pictures below.)
_____________________________________________
If you suspect a part has failed but not sure if it's the Power Supply (PSU), Processor (CPU), or motherboard at fault, you can use a multimeter to aid in locating the probable cause.
Testing the DC voltages
With the 20-pin ATX connector in the motherboard socket and AC power on, the DC voltages have to be probed from the backside of the connector by inserting the probe tip alongside the wires to contact the connector pins.
Set meter to read 20Vdc. Refer to ATX 20-pin connector pinout chart (below) and put the black probe tip to a GND pin (ie: black wires on pins 15, 16, 17).
With the Red probe tip...
1. Check Pin 9 (Purple, VSB) is about 5V. This is the standby voltage and is always on when the power supply is live to an AC source. If not 5V then problem with PSU, or a possible short circuit in motherboard or a peripheral device has caused the PSU to auto-shutdown.
2. Check Pin 14 (Green, PS_On) should be about 3~5V. If PS_On is zero Volts and VSB okay then disconnect the pc case Power On switch to see if voltage comes up, if so then bad switch.
3. Press the pc case Power On switch and PS_On should drop to ~0V.
If no change, the suspects are faulty switch or CPU. If the motherboards PS_On pins are accessible by removing the pc case's power on leads then short the 2 pins with a light tap from a screwdriver tip to trigger the power on. Another way is to use a jumper wire to short PS_On to GND. If no change in PS_On then probable fault is CPU.
With PS_On at ~0V...
4. Check Pin 8 (Gray, Power_OK) should be 3~5V to signal the CPU that power is okay to start. If not above 2.5V then signal not high enough to trigger CPU for start.
5. Pressing the Reset button (or shorting the reset pins) will make Power_OK go low (0V), and when released should go back up to 3~5V.
(Note, this may not happen if the manufacturer has used a 'soft' method to trigger the Reset.)
NOTE: If CPU doesn't POST when Power is first turned on but does POST when Reset triggered, then the initial power demand (by all devices) is to high for the PSU to handle, need to replace PSU with a better one.
With Power_OK at ~5V...
6. Refer to chart and check voltages are at proper levels on the 20-pin connector and all the peripheral power connectors inside the case.
+3.3v pins 1, 2, 11 (Orange wires)
+5V pins 4, 6, 19, 20, (Red wires)
+12V pin 10 (Yellow wires)
-5V pin 18
-12V pin 12
Note: Depending on the quality of the PSU, there may be nominal voltages detected on the +5V and +12V lines with AC live and pc power off. Always remove AC power, and wait at least 30 seconds to allow residual power to drain before working in pc case.
Testing for Continuity
UNPLUG THE COMPUTER FROM THE AC POWER, and wait 1 minute to allow residual power to drain off.
Set the multimeter to the lowest Ohms ( ? symbol) value, a typical value is 200.
Touch the probe leads together to zero the meter, note the value if it's not quite zero (live zero), this value will be used to indicate a short circuit during testing. Touch the two probe tips to bare metal inside the pc chasis, should get same zero reading.
Testing the PSU for short and open circuits...
Remove ATX connector from motherboard.
1. Keeping one probe on chasis, use other probe to check PSU's AC ground pin and the DC connectors black wire pins are reading zero. Any value other than zero indicates faulty grounding-replace PSU.
2. Keeping one probe on chasis, use other probe to check the connectors non-black wires are non-zero (if a colored wire reading less than 50 suspect a problem).
Was this helpful?
Yes
No
Solution #3
Helpful)
Hart
Rank: Apprentice
Rating: 0%, 0 votes
Originally Posted by quester12
great thread
i use a load tester on my test bench first.
i have found a few company's have missed in quality control of
the etching of the motherboards and solder bath process and let
slip possible shorts from underneeth a
Was this helpful?
Yes
No
Solution #4
posted on Feb 16, 2008
Somewhat Helpful)
kiaa
Rank: Apprentice
Rating: 70%, 1 votes
motherboard 848-7mb
After starting PC  on the screen I have post
Updating escd AND IT STAY FOREVER
Was this helpful?
Yes
No
Solution #5
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
replace the psu
Popular Solutions for HP Motherboard
Questions and Unsolved Problems for HP Motherboard
Do you recommend HP (D7580-60003) Motherboard?
Answer
Answer
my hp pavillion pc will not work....i am able to access the bios but cannot go into safe mode. can... (More)
Answer
i have hp pavilion 13121n and mechanic has informed us that dp ic needs replacement. we can get from... (More)
Answer
my board got stetic circuit
Answer
windiwos setup haff insttlions and stop erios
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
