Question about Compaq Computers & Internet
Can I add a NIC card to my compaq presario pc sr5250nx? I keep loosing my internet connection every five minutes and have to reboot the computer to reconnect
    Scholar:
  • 89 Answers
Hi!
Yes, you can add a NIC card to your computer. There are several PCI slots on the computer where you can install a NIC card. You can also use a NIC card through a USB port ( use a Linksys USB10T). After you installed the NIC card, make sure to disable the built-in NIC card.
BUT, before you do that I would suggest to try to find out first the root cause of the disconnection problem. If your PC is connected straight to a modem , check if there is a problem with the modem or from your ISP's line. You can contact your ISP (Internet Service Provider) to verify if there is no problem in your area, or have them test your modem. You can also double check if everything is working fine from the modem by connecting a different PC to it. If the connection is stable using a different PC, then the problem is indeed your computer.
Try reinstalling or updating the driver of your NIC card. Click here to download the driver ( select Fall 2007 Original Realtek LAN Driver) . After updating the driver and you still have the same problem, install a new NIC.
Good luck and have a nice day!
Posted on Oct 02, 2008
  • 781 Answers
You should be able to
http://h10032.www1.hp.com/ctg/Manual/c00840496.pdf
if your system is still within warranty I would think twice about opening the case yourself to installing a new network card.. you will be voiding your warranty.. so think about it
another thing i would try before deciding on going for another network card is to check your onboard network adapter has updated drivers... or you may want to reinstall the drivers for that adapter.. either one of those may probably fix your issue assuming is not a hardware failing given that your system may not be that old.... make sure you check the windows update and look for any new hardware driver for your network adapter that may be avaliable through windows update.
before you install your new network pci card you may have/want to disable the one on board going into your bios for that. so to ensure there's no resource conflicts when installing the driver for your new card (it may not be a problem even if you don't but if you run into problems while installing the new card consider this suggestion)
Disconnecting dap 2360
Your wireless network card in your computer is failing, or the cable to the computer is bad. Because you said wireless internet, I am going to assume that you are connected to the internet via wireless nic. If your pc hasn't been rebooted for a while you may want to try a reboot and see if that doesn't fix the issue.
However, if the problem remains you will likely need to get another wireless network card.
Nov 23, 2013 | D-Link Computers & Internet
Adding wi-fi connection
Have you installed a wireless card yet??
Apr 14, 2013 | HP Compaq Presario SR5250NX Desktop PC
Integrated ethernet card on Compaq Model SR1650NX apparently failed. What is best inexpensive PCI Ethernet Card to use, if any?
you can buy just about any PCI NIC card from ebay or even walmart and they should work. make sure they are compatible with your OS. it will say on the box.
Jun 11, 2012 | HP Compaq Presario SR1650NX...
Compaq Presario 2050NX onboard pnp nic (LAN) device not found - reinstalled onboard LAN device driver, still can't see it
For Windows XP CLICK HERE
In Windows 7 the driver installs automatically
I would suggest uninstalling all drivers for the network adapter then reboot and allow the system to find the NIC again. If this is Windows XP uninstall all drivers for the NIC, reboot, and install the above driver.
If it is Windows 7 uninstall the drive, reboot and allow device manager to locate the driver itself.
Nov 14, 2011 | Compaq Computers & Internet
I have a compaq presario sr1850nx hooked uo to Comcast broadband modem Motorola SB5100. Everytime I start or reboot my computer my connection dies. I use the comcast tool to diagnose my connection and it...
no operating system stated, wow, 14 windows and zillion linux. and PS2 OS. even freedos.
I have no idea at all what you have there;.
is this wifi or
Ethernet cable lan connected. tell helper wired or wireless.
then be more accurate as to what is there.
card, what network card, name it, model, and number.
its a desktop and as all desktops vast things can be fitted here.
NIC card PCI, LAN
Wifi card PCI, WLAN
Nic USB dongle
Wifi USB dongle.
we cant see what you have there, a photo works or words.
my guess is wifi dead, as most post here, due to complexity of wifi.
if not say so please.
Sep 09, 2017 | HP Compaq Presario SR1850NX (ER925AA) PC...
Compaq Presario 5220 Desktop Windows 98 internet: Dial-up Can a DSL card be installed or would I need to go with a wireless USB? And would wireless USB work on Win98?
You can install a network card inside the computer. You will need a PCI or an ISA card. (I know PCI network cards are easy to find at most of the computer shops.) See this site for how to install a card: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07111&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=93139 . However you should open your computer and check the space between the devices in the slots in the computer. There is an AGP slot with a video graphics card, 1 PCI/ISA slot with a modem (default specs), one free ISA slot and one free PCI slot. However depending on the graphics card one of these slots may be blocked by the card. You'll either need to get a card that fits the available slot or remove the modem and use that slot.
Here are some PCI 10/100 network cards: http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=587&name=10-100%20Ethernet%20PCI/ISA . Most of these are compatible with Win98. I'm not sure if there are any gigabit NIC with Win98 drivers.
Wired and wireless USB NIC adapters exist. However, you will be limited to the USB speed. If you have USB 1.1, that will be really slow. Most likely your computer will require a reboot anytime the connection is lost.
I hope this helps.
(who recently removed an internal modem to put in a PCI gigabit card in a newer desktop than yours. The procedure was straightforward and improved network performance in the household immensely. The failing on-board NIC was tying up the router for everyone.)
May 12, 2011 | Compaq Presario 5220 (388098-003) PC...
Nic card not working? How to troubleshoot? Is there a plug and play nic card that can be installed onto this desktop PC?
Hello Sqis,
You can purchase any nic card which is compatible with WinXP or 7.
Insert the card in PC Slot of the motherboard.
Install the driver for the card and it will work.
May 05, 2011 | HP Compaq Presario SR1650NX...
Compaq presario A75206OM
hi friend u need to contact 24 hour hp chat technision support
Jul 10, 2008 | Compaq Presario Notebook
Connection to Internet problem
you need to know what brand and model is your network interface card (nic). you need to look for the driver for this nic in order to function properly.
Jun 02, 2008 | Dell Dimension 1100 PC Desktop
Computers & Internet Logo
254 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
