This can be installed on its side as there is a retro kit for it. Sorry RyanThis can be installed on its side as there is a retro kit for it. Sorry Ryan
You can't post conmments that contain an email address.
look at page 17 here is all the install instructions plus troubleshooting
x air conditioner/heat pump
operates at reduced
performance.
x Air conditioner/heat pump
operating at low stage when
expected to operate at high
stage.
x Integrated control module
diagnostic/status LED's display
the indicated code http://www.alpinehomeair.com/related/IO-348K%208.2013.pdf
Sounds like the heat pump is not running. Check outside to see if the fan is spinning.
Try moving the thermostat to emergency heat and see if that gives you any heat. If it does, then you have heat until you can get a service technician to locate the problem with the heat pump. It could be a wide range if issues from bad thermostat to bad wiring to bad capacitor.
you can install a straight cool t stat that heats with the backup heat strip only. you can cool with ac only but using the heat pump reverse cycle will be a cheaper sourse of heat.have a pro look at it and give you some options. technology is changing so fast the best decision might be a new systemwith a new 10 year parts and labor warranty.
That low pressure switch is isolated so that would not be the issue. The defrost board is the most likely culprit but you did not post the model number to tell more
