Flash drive got bent while plug into the usb ****
  • 781 Answers
Try plugging the flash drive into another pc and see if it works.. or if the usb hub is the problem try another flash drive or usb component on the same plug and see if your computer detects it.
your question was not very clear.. but if your concern is about the flash drive been broken there's probably not much you can do if you're the one to blame for the accident. flash drives are solid state memory that can't be removed for the case and put into another case without risking damaging the chips inside and the data with it... but if you need to try make sure you protect the unit from electrostratic discharge so get another unit just like your's that is not bent, try to open the broken one and see if your memory stick inside the flash drive is still intact and just replace the casing if possible (i never done it myself but I guess it's worth to try if you really need that data)
Posted on Oct 02, 2008
Hello Kitty 8Gb flash drive isn't recognized on PC
physical damage is the most common reason a flash drive isn\'t detected. The connection between the USB connector and the circuit board can become disconnected after even normal use. A telltale sign is a loose or bent connector, but sometimes the damage is undetectable with the naked eye. if you want to do this your self..If you accept the risk and choose to repair your flash drive yourself, the first step is to apply light pressure to either side of the flash drive while it is inserted. Make sure the sound on your computer is on so you will hear the "ding" if the connection is momentarily reestablished. If you do get an indication, you can try to hold your flash drive in the position that causes it to show up. While you hold it in place, ask someone to access the drive and save your files to your computer. This requires a steady hand and if you have a lot of data on your flash drive, you might have to hold it in the same position for a long time.
Aug 09, 2014 | Hello Kitty 8GB USB Flash Drive
Bent flash drive
Unfortunately this drive is impossible to repair if bent (like from dropping while attached to laptop) and it cannot be recognized when plugged into your laptop. The silicon memory chip is sandwiched between the PCB material, if you take the case off of the outside you can observe that it is just a black square piece of silicon with no traces on the board only the metal pads to connect it intothe USB port. the "faceted" portion of the drive is only for grip and has no use other than a way to remove it from your laptop. The memory is very close into the connector, so when I dropped my laptop it bent it directly down the middle of the memory chip portion itself, undoubtedly severing thousands of microscopic connections in the chip. I believe this is a very poor design and will be buying the older "switch" style usb drives in the future.
Jan 31, 2014 | SanDisk Cruzer Facet 8GB USB 2.0 Flash...
Pendrive not working what todo?
Look at the connection to see if there are any bent connections. If not, try it in another computer. It may have just died.
Jun 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Flash drive was connected to laptop, someone leaned on it and bent it, now data access is gone. How do I fix it?
You need to pry apart the plastic casing, and then remove the metal outer jacket from the usb connector. It's probably broken when the usb plug's metal contacts connect to the circuit board. You'll need to either solder or somehow connect those points together. Don't fool with putting the metal jacket back on, just plug the port blade into the computer. You may be able to rescue your data, but you probably own't be able to save the drive after that.
Dec 31, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Bent flash drive
I am sorry. if the USB port is damaged or the PCB ( Circuit board) is damaged you are out of luck
Jul 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I bent the insert on the drive and it work?
I would first try it in a different computer. If it does not work on the other computer it is unlikely it would work anywhere. It is possible you can take it to a local computer tech service and they can try and read or fix it, but I would think it is unlikely.
If it does work on the other computer I would inspect the USB port for damage on your computer. Or the place where you plug in the flash drive into the computer, if it looks at all damaged, I would contact the manufacture for repair. You can also try other usb devices to check if it still works.
As well if the flash drive does work on other computers, and there is no visible damage to the USB port, or plug in spot, then there may be a driver or software issue on your computer.
Apr 24, 2009 | Computers & Internet
Running XP pro on a Compaq Presario Desktop AMD. Two USB ports on front of unit worked prior to reinstalling OS . Afterwards plugging in a flash drive that worked previously... Computer will Sometimes...
Check to see if the back ports behave the same way with the flash drive, If so then it appears to be a software issue. If not...look closely at the pins inside the ports and make sure none are bent. If attempting to straighten pins be sure to power system off first. Also check inside the case to see that the front USB connectors are secure. Also
Nov 28, 2008 | Computers & Internet
My flash drive was accidently bent and now windows cant read it
which compnay drive is this. u can approach them for recovery. if not damage inside it can be recovered. if u are in india than i can also help
Jun 04, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Verbatim 1GB flash drive data recovery
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Jan 22, 2008 | Electronics - Others
Flash drive was bent
You could try attaching another USB terminal/plug (soldering it), but then if you lost your files, you could try using Professional Data Recovery services... but that's expensive.
Dec 14, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
1,561 people viewed this question
David Payne
David Payne
