Question about RCA D52W19 52" Rear Projection Television
T.V. would take about an hour to warm up.
Took about an hour to warm up then would be fine for awhile then it would flicker if i turned it off then back on it would usually bring the pic back then i heard and smelt the snap from the back which i figure is the flyback from what i have read could that be the whole problem with the flickering and how long it takes to warm up?
  • RCA Master
  • 5,138 Answers
I have answer serveral times about this ck 3 capacitors on deflection board.cp150- cp111- cp114
Posted on Oct 09, 2008
Beeps that it is warm
bad weld unlikely part with leak that should have been replaced more likley
freezer way to warm sounds like the charge they put in took about 6 months to leak out the hole that was never repaired
need a servicer
Mar 29, 2017 | Viking 48 in Built In Professional...
Oven not working
http://www.geappliances.com/search/fast/infobase/10002629.htm Follow the driections here to see if they work I had the same problem and this fixed mine.
Jul 30, 2008 | Jenn-Air PRG3601P Gas Kitchen Range
Polaroid 40 in lcd tv flickering when warmed up
If the set has several thousands of hours, the CCFL tubes are about due for replacement.
Before you commit to that expense though, check the condition of the capacitors on the inverter board(s). If they are showing any signs of stress failure, replace them and try that for awhile. If they begin to fail within a year again, the tubes should be replaced with capacitors. You want to use high Ripple Current types, not general purpose types.
Sep 30, 2011 | Polaroid TLA-04011C 40 in. LCD TV
My 32TV has green light but won't turn on, or takes an hour
You may have failing power supply module, that will be the first place to look, look for caps with leaking/bulging top.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Parts: WWW.SHOPJIMMY.COM
Jun 12, 2010 | Televison & Video
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
05 aveo lights flicker in and out on tail lights and dash both
def a short ...check all wires leading to lights ....
Jul 24, 2009 | 2005 Chevrolet Aveo
BB screen is flickering on & off then turned black after in water
If your BlackBerry gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Jun 12, 2009 | RIM BlackBerry Pearl 8100
Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Mar 14, 2009 | Insignia 2.1 Speaker System (3-Piece)
Overheating problem??????
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 08, 2008 | Sony KP-57HW40 57" Rear Projection...
Monitor took half an hour to warm up, now won't start.
doubtful this is a driver issue warm up is not needed for any monitor. this is a power board issue internal to the monitor capacitors or some issue on the main power board. let me kow what you will do. good luck.
Nov 18, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
RCA D52W19 52" Rear Projection Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
