Question about Quasar HQ2101SH Air Conditioner
Discharg pressor what is the discharg pressor
  • 958 Answers
Discharge in technical term is the output of the compressor. the discharge pressure. where as the pressor you are referring to could be the compressor. the motor of the unit.
i hope i was able to help you,
tnx 4 using fixya,
drcool
Posted on Oct 02, 2008
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
6020 off problem
Not sure, but am thinking perhaps the tension disk has gunk or threads stuck in it. Try soaking a length of perl cotton in rubbing alcohol, squeeze out the excess. Raise the presser foot and loosen the tension disk as far as possible and gently pull the perl cotton DOWN through the tension disk a few times.
If that doesn't help, then it's possible a spring in the tension mechanism or something in the presser foot lever is malfunctioning.
Dec 07, 2017 | Sewing Machines
Problem with striaght stitch pressor foot
it's possible that the needle bar is out of alignment and needs to be fixed at a sewing machine shop
Mar 18, 2014 | Kenmore Sewing Machines
Flashing prewash and crease care lights
problem with the water pressor,,its not maximum pressor 5 bar,,
Jan 04, 2014 | LG Washing Machines
Hi I have a Dometic rooftop AC, when turned on the blower works but it seems when the compressor tries to initiate there is a huge power draw, the lights dim and then it returns to normal. This happens...
This is an inductation that the com[pressor is either lockup internally or you have a bad contactor or bad capisitor .. hard to tell really .. My money is the compressor is locked up for some reason. Soory to tell you this but thats where I would go first .
Aug 02, 2011 | Dometic Rooftop RV Air Conditioner
I can't get the pressor foot on the silver part came off and the actual pressor foot
Place the foot under the arm while arm is in up position. Put arm in down position and foot should snap into place (line it up where it is supposed to go together before lowering the arm).
May 11, 2010 | Brother XR-65t Mechanical Sewing Machine
Leaks after it builds up pressor
hello, have you checked your pressor relief valve to make sure it has'nt gone bad it's located on the bottom of your tank.
Mar 27, 2009 | Air Tools & Compressors
Pressor foot
Go to this link on the Brother website to order:
http://www.brother-usa.com/homesewing/modeldetail.aspx?PRODUCTID=LS2125&tab=optional
Jul 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Quasar HQ2101SH Air Conditioner Logo
55 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
