OK START WITH COLD CAR FIND HEATER HOSES (CENTER REAR OF ENG BAY) PINCH OFF HEATER HOSES WITH NIDDLE NOSE VICE GRIPS, REMOVE HEATER HOSE'S FROM HEATER CORE TUBES ( BOTH HOSES) INSTALL WATER HOSE TO ONE SIDE OF HEATER CORE , TURN WATTER ON AND LET IT FLOW 1 MIN. SHOULD DOO THE JOB, IF NOT YOU HAVE OTHER ISSUES.OH REASIMBLE EVERY THING BACK AS IT WAS BEFORE YOU STARTED, TAKE CARE WHEN REMOVING HEATER HOSES FROM HEATER CORE MAY BREAK HEATER CORE IF YOU ARE TOO RUFF,.......
Testimonial: "Thank you for taking the time to help answer my question. I hope this will take care of the problem. Thank you,Doris"
Regarding this types of problem,i suggest you to go through this help links.Click the link below to go through the procedure and troubleshoot the problem :----HOW TO REPLACE AN UPPER RADIATOR HOSE
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-upper-radiator-hose.html
HOW TO REPLACE A LOWER RADIATOR HOSEhttp://schematicsdiagram.blogspot.com/2011/07/how-to-replace-lower-radiator-hose.html
----------How to Flush Heater Core?http://schematicsdiagram.blogspot.com/2011/12/how-to-flush-heater-core.html
For heater core replacing procedure. I suggest you to go through this related help links.Its all complete step by step procedure: ----How to replace heater core for All car models?
Click the link below: ---
http://technoanswers.blogspot.com/2011/11/how-to-replace-heater-core-for-all-car.html
How to Remove Heater Core ?
http://howtobyme.blogspot.com/2011/12/how-to-remove-heater-core-on-2008-honda.html
Heater Core Replacement?
http://howtobyme.blogspot.com/2011/12/honda-heater-core-replacement.html
To replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on.html------
How to replace heater core?http://technoanswers.blogspot.in/2012/02/how-to-replace-heater-core-on_10.html
How to replace heater core on Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-replace-heater-core-on-buick.html
----------This will help.Thanks.
