How do you get to s-video on a durabrand tv, av button just goes from tv, to aux one (rca in back) to aux two (rca in front) then back to tv again?
    Genius:
  • Televison & ... Master
  • 1,673 Answers
Check to make sure that your series of set has an S-Video connector on the input panel (usualy located on the rear side of the set).
In most TV sets, the S-Video is shared with video input 1, and or 2.
For example, if the S-Video connector is located at position 1, then make sure that there are no other connectors in the video connector for the base-band video feed. The audio connectors will be okay, because S-Video does not carry the audio.
When using S-Video, the L and R audio, and the S-Connector video input will be used on the respective video input.
Jerry G.
Posted on Oct 02, 2008
I lost my remote for my durabrand tv i dont know how to check what model it is because i dont have the box... so i cant change to the game or input or aux function because i want to play video games but i...
All tv's have a sticker on the back with the model number clearly printed on it.
Most Durabrand tv's have a Source button on the case, use it to switch to the game console AV entry and back to the tv.
Aug 04, 2010 | Televison & Video
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
Durabrand TV stuck on AUX mode
You can program a Comcast remote to work with the TV. Press the "TV" button on the Comcast remote. Then, hold down the "Setup" button until the red light blinks 3 times. Enter a 5 digit code:
These are the Durabrand codes: 10171 10463 10180 10178 11034
The 10171 code worked for my Durabrand DWT1905. Then use the TV/VCR button located beneath the "7" to switch inputs.
Jul 30, 2009 | Durabrand DWT1905 TV
Trying to hook up dvd player to ET413E TV
Hi I am Vortash most Tv sets have a channel change button on the front of the set sometimes behind a drop down panel it will have the symbol AV written on it .. when pressed the set will say either Av1 AV2 etc or Aux 1 aux 2 .. if you have scart sockets on the back usually Av 1 is this socket and Av2 the front sockets Phono or Bnc plugs .. sometimes the Av is switched by pressing the program button to Zero or Av from the front set controls + and - Prog .. If you are unsure you can download a manual for your set if you don't have one from http://www.safemanuals.com
free of charge usually and it will explain all the conections you need ... Regards Vortash
Jun 08, 2009 | ESA ET413E 13" TV
I just bought a suburban that has a after market dvd and tv setup in it. It still has the orignal cd play with a dvd player under it the avd 400 ta. I can not get any sound out of it. went thru all the...
hi there
open up your dash get 1 short RCA cable (red and white) male ends on them
now place the red and white RCA into the back of DVD in-dash player next step the aftermarket CD player should have 2 rca plugs that say aux put the other end red and white RCA cable that you just put into DVD unit into the aux inputs on back of CD player when this is done reinstall both units back into the dash now on your CD player press the source button till aux appears once this is done you will hear the DVD player sound...........now if you press the source button and no aux appears......hold down the source button till the CD player powers off...........once CD player is off hold down the F (function) button till beep or unit turns on a display use the skip buttons or F (function) button to go threw features once you get to aux turn aux to on now hold the source button down again till unit powers on normally once this is done press source button again till you find aux........if you get sound and the TV doesn't work let me know and ill guide you to get that running too (if there are no aux RCA plugs on the back of CD player) let me know (sometimes there is a headphone looking plug on back of CD units) if what i told you doesn't work let me know the brand of CD player you have so i can give you correct setups I'm only going by your in-dash DVD player right now
hope i was able to help get you sound
Mar 04, 2009 | Audiovox AVD400TA Mobile DVD Player -...
Durabrand 13 in trying to hookup gamecube
If the TV says AUX it might be trying to use the S-video if you have it. Try wiggling the Yellow video input while its connected... something might be lose my neices Durabrand does this. Do you have the remote still that has the GAME button on it? If not 3 digit code 189 works for Durabrands
Apr 10, 2008 | Durabrand BH1304D 13" TV
Durabrand 13" tv model BH1304D
You will need the original remote control I,m afraid. The original remote is the Durabrand HYF-23A. On the original remote, incase you do have one, is a button marked TV/AV. That is the button that changes between the TV and the Audio/video inputs. An original replacement remote can be purchaed HERE: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=BH1304D&brand_pn=DURABRAND_BH1304D&mode=large&uid=11831222740150 Good Luck
Jun 29, 2007 | Durabrand BH1304D 13" TV
Durabrand DCF2003
All you need is to press the input select button on the remote to change between the tv and the video inputs.
May 23, 2007 | Durabrand DWT1905 TV
Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Jul 21, 2006 | Emerson SpongeBob SquarePants TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
