Question about HP LaserJet 3330 All-In-One Printer
Scanner Error power on power off
HP Laser Jet 3330 has been working fine until recently, but now shows the above message?
Try turning off, but comes back i a few minutes
    Scholar:
  • 116 Answers
There is a sensor in the paper feeder tray which is also connected to the scanner area that sensor is bit moved from its orignal position or is slightly broken while the paper jam or while removing the paper jam.
please check the sensor.and make it proper.the error will go.
Posted on Oct 05, 2008
How do I fix a dark streak down center of scanned document on HP laser jet 3330
Lines and streaks are usually caused by ink or trash blocking the scanner pickup. You need to open the top of the scanner and clean the scanner glass. Here is a link to a guide that shows where to look for something blocking the sensor.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
May 07, 2012 | HP LaserJet 3330 All-In-One Printer
Hp 3330 laser jet memory low error when faxing
1)Press ENTER/MENU
2)Simultaneously PRESS then RELEASE * then # to enter Developers Reset(This is a soft reset. No loss of data or configuration settings).
3) Press < or > button until the message REINIT FFS appears on the second line of the control panel.
4) Press MENU/ENTER.
5)Takes about 2.5 minutes.
6) When READY appears on display press CANCEL to exit.
Apr 02, 2010 | HP LaserJet 3330 All-In-One Printer
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the
control-panel display.
4. Press MENU/ENTER.
5. The process takes approximately 2.5 minutes. During that time, the control-panel display
will change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
Scanner error
You will have to replace the scanner assembly.
HP Part # C9124-60103
This replacement shoult take 20 minutes.
Jan 01, 2009 | HP LaserJet 3330 All-In-One Printer
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
there is a sensor in the paper feeder tray which is also connected to the scanner area that sensor is bit moved from its orignal position or is slightly broken while the paper jam or while removing the paper jam.
Oct 05, 2008 | HP LaserJet 3330 All-In-One Printer
Proble with HP laserjet 3330
You will have to have the scanner assembly replaced. There were some problems with the earlier versions and they have seen been rectified. I have not had a single one come back in after replacing it.
Jun 01, 2008 | HP LaserJet 3330 All-In-One Printer
HP LASER JET 3330
Sounds like the scanner bulb mate. There is a post on here already about how to fix the scanner bulb problem.
Hope you fix it
Apr 05, 2008 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
