Below are some pictures for you. I will give you a hint incase you don't know. If you look at the botom picture, it shows you the tensioner. You will want to push the rod until you can put the hex wrench through the hole to hold the rod. Then install the dust cover. When put the tensioner back on you will want to alternate back and forth on the 2 bolts so it's good and even and then remove the hex wrench. Hope this helps and good luck.
Below is the master help link
provided to go through belt routing diagram:---Timing belt, drive belt,
serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all
types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
