Question about Canon PowerShot SD600 Digital Camera
Battery pack or charger
How can I tell which is the problem?
    Scholar:
  • 89 Answers
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
Posted on Oct 02, 2008
You would think they mit would at least be willing to tell us what other battery & charger would work for this drill/driver. their tools must not be as good as they are advertised to be.
why would any manufacturer refer you to a competitors part when they have their own to sell---get real
now batteries can be replaced in a battery pack and there are plenty of battery shops that can do that for you
What's more most will have a generic charger that will do the job if not the OEM charger or can test your charger
remember this --the price of a battery drill is directly related to the quality of the batteries in the pack
a quality brand that is cheap indicates poor quality batteries or if it is a quality brand and has several spare packs again the batteries are of poor quality
so the fix is to visit a battery shop with your pack and charger and ask questions of them
Oct 28, 2017 | Drills
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Hi i have an HP Elite Book 6230p,my laptop stop charging recently, i was charging it and i removed my charger plugged in another charger of lower current rating it worked well for a while, but when i...
Nice books, have many. 8540s./. better.
i can not decode this post.
sorry
does it run with no battery and the correct pack
mine has 10 options new the i7 and the fast video card suck huge power and mine needs a 100watt pack, the 65w on mine is HOPELESS. see?
run the correct matching pack,
step 2 a new battery, i keep 2 good ones all the time
on Vacation, id not be wanting to find batteries 3000 south of here, ever. (south of the boarder)
test with no battery
then with correct power pack (the charger is a chip inside the pc and in this 19vdc pack its only a power pack pure DC.
then try a new battery ,
if you read your service manual at HP.com
it tells you all packs used and why, and the match.
sure does.
and varies by OPTIONS DAY1. in all case
unless upgraded like mine, is, and sucks max amps mine does.
Jul 03, 2017 | HP EliteBook 6930p Notebook PC
How can i charge my onboard battery offboard? ineed to take the batter off and charge it indoors
Keith You have to remove the seat from the scooter and then lift the battery pack out of the frame. On the front of the battery pack there should be a charger port where you can plug in the charger into the battery pack when you are inside. Plug your charger into the battery pack first then plug it into the receptacle. When fully charged unplug from the receptacle first then unplug it from the battery pack. In other words always have the charger unplugged from the power when plugging and unplugging it from the battery pack. Velcro is holding the pack down so you might have to give it a good yank to get it off the frame. Hope this helps
Oct 20, 2010 | Pride Mobility Products Go-Go Elite...
My kodak easyshare camera isn't charging.....we already bought a new battery...and it still wont charge?? The charger is still good and working?
My kodak camera requires taking out the battery pack and charging outside of the camera. My batteries have a generic charger I got off of amazon that has a red and green light on it that tells you whent he batteries are fully charged.
If the charger is blown, that might explain why they are not charging.
Are you trying to use AA batteries instead of the recommended battery pack? I would use the recommended battery packs available through amazon.com.
Jun 25, 2010 | Cameras
How to charge Panasonic lumix DMC-FS4
hello there use your USB cable for charging your camera battery. No need to take out the battery from camera. Some Tips.
  • You may choose our Smart Charger (0.5A,UL listed) for 3.7 V Li-Ion battery Pack to recharge this battery pack. Must charge the battery pack with correct polarity. The estimated charging time is 2.76 hours .
  • You may connect two 3.6v 920 mah pack in either series or parallel connection for making a higher voltage and higher capacity pack.
  • Hope you have those staff with your camera. use that for charging. Follow the link.
    http://www.batteryspace.com/smartcharger05afor37vli-ionpolymerrechargeablebatterypack--ceullisted.aspx
    Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
    Jan 31, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
    Dewalt battery charger won't charge
    As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
    Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
    Batteries show charged but no pwr
    Clamp one side of [power line of your charger insert baterry pack,if amphere increase the battery pack was ok.select battery good one still run impact diver insert to the charger amphere increase good charger and battery pack. Two only the problem Battery pack or charger, if charger not function , the power transistor will be replace or buy new charger.
    Dec 25, 2007 | Makita 18V LXT Lithium - Ion Cordless...
    Canon PowerShot SD600 Digital Camera Logo
    173 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Doberman
    Are you a Canon Camera Expert? Answer questions, earn points and help others
