Question about Jensen CD4610 CD Player
Auxiliary port location?!?! where would it be?
I just purchased a 91 geo prism which the previous owner had installed the cd4610, and i noticed that it has an aux mode, but i can't find the port so i can connect my ipod. is it just that my car doesn't have one, or am i simply not finding it? i've searched high and low on google and can't find a solution, and i'd like some help before i give in to making cds or using an fm transmitter, both ideas i'd really like to avoid if i could.
thanks!
  • tweetyb654 Nov 07, 2008
    I have the same exact problem. Nowhere in the manual does it say where the auxiliary jack is, and I know it has an aux mode. The girl I bought the car from said that she listened to her iPod in the car, and have no idea how.
  • 3 Answers
The yellow wires on back one has a white cap the other has a red cap those are the input wires you need to buy the cord that goes from a red and white RCA jack to a 3.5mm headphone jack
Posted on Jun 08, 2009
I have a '91 geo prism... I need to replace the glass for the headlight how do if that?
buy a new headlamp assembly-aftermarket-they are cheap and readily avalable- cheers Denny
Nov 14, 2013 | Cars & Trucks
How to replace the brake light switch in my 1995 Geo Prism. And where it is located.
IS LOCATED ON THE TOP OF THE BRAKE PEDDAL AND THEIR ARE 2 SCREW TO REMOVE IT AND A WIRE CLIP TO UN PLUG AND ITS OUT
Aug 03, 2011 | 1996 Geo Prizm
1994 geo prism, fuse blew, I don't have manual
the only fuse for the starter is not located in the fuse box it is located in the positive wires that go to the starter its called a fusible link and when then amperage of the starter exceeds the fusible link rating the fusible link blows the link is usually located inthe positive wire to the starter and at some point fatter then the wire itself
May 04, 2010 | 1990 Geo Prizm
Need a map sensor for Geo Prism 1995 year, Where can i locate this item.
In 1995 Geo Prizm 1.8L MFI DOHC 4cyl the MAP Sensor is located under hood, passenger side, rear engine area, mounted on upper firewall.
Hope this help.
Mar 31, 2010 | 1995 Geo Prizm
How do i install a gas tank in a 1996 geo prism
the safest way for this repair is go down to your local parts store an purchase a repair manual for your specific vehicle ,usually around 20 dollars this will help you alot with step by step instructions
Aug 07, 2009 | 1996 Geo Prizm
I installed a new a/c compressor on a 91 geo metro.Where does the compressor oil go into the compressor at?
The compressor's oil is mixed with and circulates with the refrigerant. R134a refrigerant can be purchased with or without oil mixed into it. There are also separate oil 'chargers' that inject oil without the refrigerant.
Jul 01, 2009 | 1991 Geo Metro
Fuse replacement for 94 Geo Prism
just unbolt it and replace it, that easy
Mar 12, 2009 | 1994 Geo Prizm
On a 1991 geo tracker trying to find location of fuel pump relay?
The fuel pump relays are mounted on an "L" bracket underneath the ECM. Both have something to do with the Fuel pump. Be careful not to get it confused with the horn relay it is in the same vicinity (under the dash on the drivers side).
Feb 18, 2009 | 1991 Geo Tracker
Location of fuel filter-1990 Geo Prism
Right under the master brake cylinder, its really hard to replace it. It has 2 screws, one bolt on top and the bottom one needs to be screwed off under the car
Aug 06, 2008 | 1990 Geo Prizm
Car radio code
The unit is locked your appointed dealer or delco can unlock it for you. You may need proof of how you obtained it. if you know the sets history a previous owner may remember the code he used.
flyingfox@people.net.au
Jun 16, 2008 | Radio Communications
Jensen CD4610 CD Player Logo
830 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
