The mouse on my laptop stopped working (I have trouble using the touch pad).
I think the mouse issue is a problem with the USB ports -- it does not work in either port (I tried a brand new mouse which doesn't work either. At the time this startted I was experiencing random shut downs, which seem to have stopped.
I have not added any software. The only thing that changed was I moved offices and plugged the laptod into a surge protector rather than right into the wall socket, which i had been doing. Also, I plugged the ethernet cable for hte T1 connection into a router rather inte the wall which I had been doing as well.
I'm stumped. Any ideas/thoughts would be appreciated.
-   the usb drivers can not be found in the driver list,looks like it has been delated
-   desdicado
Feb 20, 2008
-   usb-   Guest
Dec 04, 2007
-   Hi,
I just got a used Tecra8100 and can only locate one usb port - in the rear 'right' corner (as you look at the screen) under a thin 'door'.Users - and the Device Mgr - mention 2 usb ports.Where is the 2nd one hiding?
-   All the drivers are re-installed and working fine but still am unable to use the usb ports.-   saq9
Solution #1
posted on May 30, 2006
Mini Me - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Goto system properties, hardware, device manager Check if your USB drivers are installed- are there any driver errors? Reinstall them anyways just in case.
I have a Acer Ferrari 3200 with UJ-825S Combo DVD+CDRW broken and I would like to replace it. I...
(More)
I have a Acer Ferrari 3200 with UJ-825S Combo DVD+CDRW broken and I would like to replace it. I found the UJ-825-C to replace it, but I don't know if it's compatible. Do you know if it's?
I have a new HP 9827 that has a short right shift key. I understand that one can modify the MS Vista...
(More)
I have a new HP 9827 that has a short right shift key. I understand that one can modify the MS Vista code to get the uparrow to swap out the shift key.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
