Question about Refrigerators
Maytag plus refrigetor not cooling model msd2756geb
I have a Maytag Plus side by side refrigerator and the freezer is cooling fine but there is no cold air coming into the refrigerator. I blew out the coil in the back and the fan is constantly running. Does anyone know why the freezer would be blowing in cold air but there is no air coming into the refrigerator? We turned the refrigerator all the way to 9 which is the highest and I still don't feel any cold air coming into the refrigerator. I was told that the air for the fridge comes through from the freezer. I don't know what to do. If anyone knows I would appreciate some advice.
Thanks,
Jared
  • jeff_ca Oct 17, 2008
    I have the same issue with my 4 year old MSD2756GEB unit. This just started today, called Sears (where originally purchased), repair will be here in two days to take a look. We've had them (Sears) look at this unit twice in 4 years, for the complaint "Fridge doesn't seem to be cooling correctly", each time they've come out, problem won't repeat, but they crank the temp control up, and up .. it's now at 8 1/2 (gauge only goes to 9) but the freezer is at 4, and keeps things frozen perfectly, no ice buildup, no issues whatsoever. If I get a "Fix" for this, I'll post here, otherwise, any suggestions would be appreciated --- a lot of money to spend to have this go bad so soon. Thanks!
After removing all of the freezer racks and shelf pull the 4 1/4 inch screws out at the bottom back panel of the freezer. pull the 2 panels off and slide them out strait down to the floor of the freezer. if your freezer coils are full of snow and ice then the fan cant pull any cold air up into the refrigerator.your problem is probably th defrost adaptive timer. if the heater ohms out at around 20 to 30 ohms it is ok. next ohm the 2 white wires at the plug this is checking the thermostat it shoud ohm out at aproximately 240 k ohms if those 2 things check out the problem is the adaptive defrost timer it is in the ceiling behind the temperature controls on yhe right side.
Posted on Aug 05, 2009
My Maytag Plus side-by-side refrigerator model # MZD2766GES is not keeping anything cold. The freezer side seems to be working just fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Oct 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag plus refrigerator is not cooling properly freezer works fine model # msd2756deq
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 18, 2011 | Refrigerators
Refrigerator not cooling: Maytag Plus: Model MSD2756GEQ
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
Aug 15, 2009 | Maytag MSD2758G Side by Side Refrigerator
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
I have a Maytag side-by-side MSD2756GEB that quit cooling.
sounds like either the fan motor or the compressor. go ahead and open upo the bottom baclk panel and see if the fan is running or if the compressor is. could be just a burned wire.
Feb 07, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
2003 Maytag Plus Dual Cool Side by Side
Check to see if the bacl of the fridge is iced over, if it is the fridge is not defrosting, 99% of the time it is the defrost control circuit board located in the upper right hand corner of the fridge.
Jun 09, 2008 | Maytag MZD2766GES Side by Side...
Maytag S/S model # MSD2756GEB
di you see or hear the fan running fan might be stuck check that out no fan no circulating cold air you may have problem with the heating element what make frost free inside you should melt all the ice inside around the damper check if you see broken glass the little heating element if it not broken and listen for that important fan if it running check it uot thank for using fixya pierre
Feb 05, 2008 | Refrigerators
Need help on Maytag Plus Ref
First check for a thick frost buildup on the back panel of the freezer at the bottom.  Also, check to see if the fan in the freezer is running.  Let me know what you find so I can lead you in the right direction.
Oct 18, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
680 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
