Question about Sovereign ARP-1200EX Air Conditioner
My new (used three times) unit has petered out and now blows only warm air a 10 x 10 room is 82 degrees and getting hotter! help
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
My rv air condition also has heat, the heat in it is not getting very warm. So days it will burn u out of it and some days it just blows cool air! Any suggestions. It is a dometic
Check the following if you're unit is not giving heat.
1. Keep temp setting +8 degree from your room temp 2. Keep mode in "Heat". And check the click sound in RV when you turn to heat mode. If one failed out of three your unit will not supply heat.
Dec 15, 2010 | Heating & Cooling
Air conditioner/furnace was working for the past few months. Came home today at it is at 81 degrees, although my set temperature was set at 72 degrees. Temperature is rising to 83 degrees and I can't...
Check outside breakers. Open up outside panel and see if contactor is pulled in. If so you have a voltage problem or a bad capacitor. Sometimes a wire burns off. So look for this. If you have a float switch on the inside unit it may be tripped. Stopped up drain. Russ
Jul 30, 2009 | Heating & Cooling
Air Con Unit Not cooling the room
Alright, I'm obviously not there, but you could be low on refrigerant/Freon, and what is more likely, your AC is suffering from some sort of obstruction or debris, as noted in this handy diagnostic article that explains how it could cause your AC not to blow as cold air as you would like:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Hope this helps.
Brad
P.S. As to the loss of your operating manual, try to see if you can get another one directly from the manufacturer by contacting it.
Jun 04, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Cold air out of register for about 3 min. until starting to warm
heat pumps generate heat from compressing freon and take a while to generate enough heat to be useful. never expect robust heat from a pump like an oil burner or a gas furnace, but they do heat great and are cheaper to operate. do this . if you are still using an old mercury bulb stat change it to a digital one. this will hold an exact temperature and time off between cycles will be less and the indoor coil will stay warm between short cycles, with an old mercurry stat you set it at 70 and it may run up to 73 and stay off till 68. thats a long off cycle and when call resumes the coil has gotten cold and has to start all over again. also dont wait till it gets cold to run a heat pump. turning it on and off as it gets cold is not correct. you should select a temp ,usually 71 for heat and set it and leave it on to do its thing.you may want to check the charge. hot gas discharge is usually 100 degreees hotter than outdoor temps after 15 minutes run time. for example if its 40 outside the big freon line outside thats insulated should be about 140 degrees. or you can run it 15 minutes and grab it with your hand . it should be almost uncomfortable to hold any length of time. careful some get quite hot. you also have the option of hooking up the electric strip to automatically come on if you push the stat up 2 degrees hotter than the temp in the room. that way you get heat pump and strips till temp gets within 2 degrees of set point and the strips shut off and pump maintains.good luck
Nov 01, 2008 | Goodman CLQ36AR49 Air Conditioner
I bought a Lg 11,500 btu air conditioner yesterday at home depot. It has been set on 60 degrees with the fan on high and will only bring my room temp down to 79....it does not feel cool
An 11'500 btu Is appr. 1 ton of cooling capacity or enough to cool approximatly 450 sq ft of floor area. Be sure to read the instructions of course and be sure that all the packaging material was removed that may be restricting airflow. On high you should be able to easily feel the air blowing 10-15 ft from the unit and the air should be dropping about 15- 20 degrees when it exits the unit. So if the room temperature is 85 degrees the air exiting the unit should be around 65 -70. The amount of time it takes to cool the entire room depends on how big the room is and how much and the intensity of the heat infiltrating the room and the number and heat output of appliances and people in the room. Hope this helps you out GL!
Jun 11, 2008 | LG Heating & Cooling
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Sovereign ARP-1200EX Air Conditioner Logo
46 people viewed this question
Top Sovereign Heating & Cooling Experts
NOEL
NOEL
MightyMikeJr
Are you a Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
