Question about Toshiba Sattelite A105-S2071 Notebook
My reseaver for my sattalite is not reading the horizontal axis only the vertical what could be wrong?
Whats the answer to y=(x+2)^2 using a new equation in vertical form a transfer right 4 unit up 2 unit and reflect on x axis
Let's start with the original equation. It is in the form y=a(x-h)^2+k, where (h,k) is the vertex. In this case, h= - 2 and k= 0. Thus, is it y=x^2 and we have done a horizontal translation 2 units to the left. I assume we are going to translate this 4 units to the right, then 2 units up, and then reflect it in the x-axis. Before we do the reflection, we will be 2 units to the right and 2 units up. This equation would be y=(x-2)^2+2. If we reflect this in the x-axis, would we get a downward facing parabola y=-(x-2)^2 -2?
Good luck,
Dec 06, 2015 | Office Equipment & Supplies
Draw a line graph of water temperature vs time
On the x-axis (horizontal axis) represent the time variable. On the y-axis (vertical axis) represent the temperature.
Mar 03, 2014 | Texas Instruments TI-84 Plus Calculator
I was cleaning the dust out of the feed dog area and somehow disconnected the feed dog from the lever in the back that raises it and lowers it. How can I reattache them?
A feed system for a sewing machine having a frame, a horizontal arm shaft journalled in said frame, a vertical arm shaft extending downwardly from adjacent said horizontal arm shaft, means rotatably connecting said horizontal arm shaft to said vertical arm shaft, said feed system comprising a cam fixed to said horizontal arm shaft, a sheet metal feed fork having parallel bent over portions at one end thereof embracing said cam and in driving engagement therewith, a feed rock shaft supported in said frame and having an arm connected to the other end of said feed fork, feed regulating means carried by said frame and connected to said feed fork for converting motion induced by said feed cam to oscillations of said rock shaft, said rock shaft being formed with a pair of upright rock arms on the other end thereof, a horizontally disposed U-shaped sheet metal feed dog carrier having each end thereof connected to one of said upright rock arms, said feed dog carrier having a horizontal shelf extending from the base of the U between the ends thereof, said shelf supporting thereon a feed dog, means for attaching said feed dog to said shelf, a stud affixed to said base of said feed dog carrier beneath said shelf, a sheet metal lift lever pivotally supported on a horizontal axis in said frame substantially parallel to said rock shaft, said lift lever having a slotted end for engagement with said stud extending from said feed dog carrier, said lift lever having the other end thereof supporting a cam follower adjacent said vertical cam shaft, and a lift cam removably affixed to said vertical cam shaft and in engagement with said cam follower on said lift lever.
Take care.
Oct 20, 2010 | Kenmore 19110 Computerized Sewing Machine
Do not have full picture
Not all programs display in correct format. Chosing a stretch option from the TV remote or Cable remote is usually the only option. Aside from going into the menu settings and changing the Horizontal & Vertical axis.
Sep 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Image problem
IF I understand the problem from the limited info in your question, the problem is a distorted picture on whatever surface [probably a wall, or screen] onto which the image is projected.
With all lenses, the axis [centerline of the lens projected] MUST be absolutely PERPENDICULAR [in both the vertical and horizontal planes] to the perfectly plane [flat] surface onto which the image is projected.
IF for example, the projector is mounted in a rear corner of the room, and the camera is aimed downward and to one side to project the image on the center of the opposite wall, or a screen located there, the image will be distorted. It will be larger on one edge [fartherist from the lens] and smaller on the opposite [nearest] edge.
If it is non-perpendicular in only one axis, then two opposite edges will be different lengths, and if out of perpendicular in two axis then no edges will be the same length.
The solution to this problem is that the center axis of the lens must be perpendicular to the surface projected on, in both vertical and horizontal axis.
Feb 14, 2009 | Sharp BQC-XGE630U/1 Projector Lamp for...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Whirlpool Duet GHW9150PW4 - Stinky Cloths
have you tried cutting back on detergent.. due to low water use of machine if too many suds/detergent suds and detergent may not get completely rinsed out also be sure you were using HE detergents low suds high efficent..preferably any but tide it tends to suds the most of any HE
Sep 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Trouble tracking vertically
dust stuck inside the trackball on the vertical axis maybe. Otherwise faulty device, you should return it
What is the focusing screen display?
There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Toshiba Sattelite A105-S2071 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
