Poor picture quality - Televison & Video
  • brandfarm Jan 28, 2009
    I have a jvc hd-52z585 52 in rear projection hdtv television. It has a very grainy picture and is not crisp at all. Do I need to change the lamp? I bought this used and it had flashed on the screen once that I should change the lamp.
  • Landon V.W May 11, 2010
    What is you tv model and i might be able to help.
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs poor picture quality - 578ba6c.jpghanged.
578ba6c.jpgTV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 22, 2009
50p8341a
Posted on Oct 20, 2008
  • 51 Answers
Make sure all of the cables are plugged in tightly and that it is a good tv. and then if that no work call your dealer and ask for assitance. i hope this helps, post more detail for more help from me.
Posted on Oct 02, 2008
Why do most security cameras shoot poor quality pictures ...
https://www.quora.com/Why-do-most-security-cameras-shoot-por-q... QuoraA good surveillance camera must have compact size, acceptable frame rate, ... Digital Cameras: How is the picture quality of the Samsung Galaxy S4 Zoom?
Why is DSLR cameras video quality so poor compared to ...
https://www.quora.com/Why-is-DSLR-cameras-video-quality QuoraWhy is DSLR cameras video quality so poor compared to still images at same resolution ... How does a digital camera work when taking a photo whose (image) ...
DigiTools: Communication, Information, and Technology Skills
https://books.google.com/books?isbn=0538741295
Jan 03, 2016 | Cameras
Poor print quality
Can you add a picture of poor quality?
Apr 04, 2014 | Lexmark LEXE260X22G - E260X22G...
Poor color quality (Canon Pixma pro 9500)
recalibrate the printhead, clean the printhead. In the printer driver you need to select the right paper.
Jun 09, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Poor picture quality, the picture is blurred and
You have problem with convergence. Have you tried adjusting in the users menu. This is a common problem in this type of TV, usually two convergence amp need to be replaced and sometimes sets of resistors are also to be changed.
Mar 02, 2010 | Sony KP-43T70 43" Rear Projection...
Picture quality poor on certain channels,get all of bbc channels ok rest loss of sound and hick ups in picture
if all channels poor quality TV problem
if just one or tow channels bad quality not tv problem....
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Picture Quality Iphone
This is normal. Most pictures you see on websites are small representations. Try going to a wallpaper or background website, click on larger pictures and zoom in then.
As for Youtube, this is normal to have ratty quality videos. this is also dependent on your bandwidth, so it may drop in quality in a low reception area, but wifi should be pretty decent, just still typical YouTube quality.
Mar 10, 2009 | Apple iPhone 3G
Poor picture quality on old 55" rear projection phillips tv
replace the coolant in the CRts. Very common problem with the older rear projection tvs. You can get the coolant replacment kit at the following link which contains the coolant and instruction CD.
http://servicemanuals.vstore.ca/
Dec 19, 2008 | Televison & Video
Poor quality picture
Is the TV set on Ch 3 or 4 or are you using Line in/aux?
Feb 19, 2008 | Televison & Video
Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
Nov 27, 2007 | Canon PowerShot A430 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Televison & Video Logo
513 people viewed this question
Top Televison & Video Experts
Electro Med Services...
