Acer Ferrari 3200 PC Notebook
Problem for Acer Ferrari 3200 PC Notebook
Using exernal drive with laptop
By paulrmc - usenet poster
OK, guys---we've got a couple of rocket scientists (not) hard at work, and we've run up against a stump. Let me give the background of the problem, and tell what we're up to.
Got a friend who has a laptop. His hard drive crashed awhile back. He took the laptop to a pc shop and got a new hard drive installed. He was checking out options of recovering his files off the old hard drive. I told him same thing had happened to me, and the way I did it was to take out my bad hard drive, get all the numbers off it, find a new identical one, then take the controller boards off and swap the suspect bad one for the known good one, and then stuff the hard drive back in my pc. It worked fine, and I was able to copy off my files.
My friend has now done the same thing, and has his old hard drive ready to go, with a new controller board on it.
He's trying to simply get the hard drive to run as an external drive, without having to go inside the laptop and swap the new/old drives out. He's got USB ports available.
This morning, he tried using the old hard drive from a USB port. So far, his laptop doesn't let him do this. Bear in mind that the disk inside the hard drive is already partitioned and formatted, and has data on it that he doesn't want to lose.
We can eventually take the new hard drive out of the laptop, and put the old one if, if we have to. This is our approach of last resort, though.
So, does anyone have any neat tricks we can try to get the laptop to recognize its old now external hard drive?
PS: my friend does have an IDE adapter cable if that's what we should use.
Same Problem
Jul 19, 2008
-   I have already posted my question which is the USB Port not working for my HP Compaq nx9030 laptop. -   fhsaraiva
Jul 19, 2008
-   My USB ports not working. I am unable to use an usb device driver such as flash driver, pen, external usb hard disc. -   fhsaraiva
Best Solution
posted on Mar 28, 2007
Very Helpful)
hagrid
Rank: Apprentice
Rating: 95%, 2 votes
switching out drives in laptop is quick and easy. trying to boot from usb needs usb boot set up in bios. Sounds like you have changed boards, does it spin up? Sorry reread message, he has a new drive in computer but now wants to get info off old hard drive. You say you tried a usb connector? onto old drive. did it spin up? is conector on drive correct way? WILL fit differant positions but will only work in one position. but it could be like other poster said, drive itself toast. As a LAST RESORT you can put drive in bag, freeze it then quickly conect it and try accessing drive. this does work sometimes but only as a LAST RESORT
Was this helpful?
Yes
No
Solution #2
posted on May 30, 2006
Somewhat Helpful)
Duke
Rank: Apprentice
Rating: 0%, 0 votes
If the physical disk is damage or the internal parts are not functioning, just changing the controller board will not work. You would need to send it to a data recovery facility, with a clean room, to extract the data.
Was this helpful?
Yes
No
Solution #3
posted on Nov 12, 2007
Not Rated)
dave_dial
Rank: Guide
Rating: 93%, 4 votes
What I use for this purpose is a USB-IDE adapter cable and external power supply, both of which are sold as a pair. I've bought them from Surpluscomputers.com and Newegg.com. Just google "USB IDE adapter cable" and take your choice. You should be able to find one for $15 (as of Fall 2007).
The cable has a connector with a 3.5" connector on one side and a 2.5" connector on the other side. Set the hard drive jumper to MASTER on a 3.5" drive. 2.5" hard disks are already preset to MASTER. Connect the IDE connector first. Then plug in the power supply if you have a 3.5" drive. Once the drive has spun up to speed, then plug the USB connector on the cable into an available USB socket. The drive should show up soon in My Computer or Windows Explorer under Windows 2000/XP/Vista. Be a bit patient; it doesn't happen right away. The cable kit should come with a Win98 driver on a CDROM, if you are working with an old machine.
WARNING: A drive cannot be formatted with this cable; you will have to format the drive elsewhere in another computer first using a direct connection to the IDE bus.
Was this helpful?
Yes
No
Solution #4
posted on Aug 25, 2007
Not Rated)
Tom Smith
Rank: Wiz
Rating: 83%, 98 votes
If you are trying to boot the laptop off USB r31's dont support booting off r31s.
Was this helpful?
Yes
No
Solution #5
posted on Jul 26, 2007
Not Rated)
polofly
Rank: Apprentice
Rating: 0%, 0 votes
u can also do the safe mode scandisk. then try to backup the files.
Was this helpful?
Yes
No
Solution #6
posted on Jul 09, 2007
Not Rated)
tuyetminh
Rank: Apprentice
Rating: 0%, 0 votes
your sys. can't recognize your old one with USB interface because it format by NTFS all your friend do to using IDE cable for PC with Laptop adapter,conn. to pc coppy all data uwant save then format it with FAT or FAT32 it will recognize fro sure, if not I give you mine.
good luck
Was this helpful?
Yes
No
Popular Solutions for Acer Ferrari 3200 PC Notebook
Questions and Unsolved Problems for Acer Ferrari 3200 PC Notebook
Do you recommend Acer Ferrari 3200 PC Notebook?
Answer
Answer
The DVD drive plays audio files but not video
Answer
laptop cheeps rebooting after boot flash screen
Answer
IDE 0 Error. he cambiado el disco por otro y persiste el error. a que se debe??? thanks a lot
Answer
I have a Acer Ferrari 3200 with UJ-825S Combo DVD+CDRW broken and I would like to replace it. I... (More)
Answer
I have a new HP 9827 that has a short right shift key. I understand that one can modify the MS Vista... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Ferrari 3200 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
