Question about Compaq Computers & Internet
Can not use the regular its keep makes you go to the touch pad and can not type
  • Francisco Cortes
    Francisco Cortes May 11, 2010
    It sounds like you a have problem with the touch pad and you can't type but the way your questions was constructed is kind of hard to make some real sense out of it..
    how about rephrasing your question and giving out more details like, what operating system, what type laptop you got and what is it exactly that you can and can't do.
  • 35 Answers
The way your questions was constructed is kind of hard to make some real sense out of it..
please give the type of os and what type of system youhave?
Posted on Oct 02, 2008
My typing keeps jumping around on my Dell vostro 2520 laptop, shut on internal pad but still jumps around with my Logitech mouse
Regular answer for this problem is to update BIOS / Touchpad drivers. Since you have already disabled the internal touch pad, can you also check if you have a track-stick that needs to be disabled. That should fix your problem!
Drivers available on Dell's award winning support site :)
Oct 12, 2013 | Dell Vostro 1510 Laptop
Hp laptop windows 7. touchpad locks for no reason. how do i unlock it?
Search for the button for PAD LOCK, of press Fn + some other buton to unlock...
and next time write pc model.
Jul 09, 2012 | HP Computers & Internet
Acer laptop screen keeps rolling and I cannot type. cursor runs away to the top.
Make sure that you are not touching the touch pad while typing. Reinstall or install an updated touchpad driver for your laptop to help control the cursor.
Hope this helps.
Jun 13, 2011 | Computers & Internet
When I type on my keyboard, the pointer skips around. I can be typing on one line and all of a sudden, the typing is in another place.
hello, This happens because you are landing some part your hand (palm) in the touch-pad when you typing. which activates the touch-pad and makes sudden movements in the pointer.
This problems for lot of laptop users, unless you can get use to prevent the hand from touching the touch-pad, the only option is getting a USB keyboard where you can plug in without any drivers and type without any trouble.
Mar 30, 2011 | Dell Inspiron 6000 Laptop Keyboard 0H5639
Hello, my samsung n150plus's cursor keeps skipping make it difficult to type. Please, help!
I had the same problem and discovered that when I was typing my thumbs where touching the touch pad and that was causing the problem. I now type with my thumbs up and not touching the pad. I hope this helps.
Dec 12, 2010 | Samsung N150 (36725723009) Netbook
When i am typing the cursor will suddenly move to the middle of what i have already typed , it is driving me potty and i have to keep re typing things , is there anyway to stop this? sunshine
I was experiencing this problem before, and I figured out I was tapping the touch pad with the palm of my hand. I had to download a driver for my touch pad and adjust the sensitivity of the touch pad.
Mar 01, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Keyboard problem- cursor keeps jumping around when I'm typing
You may be inadvertently touching the touch pad with the side of your hand or fingers as you type OR the touch pad itself is bad and needs replacement.
Jan 07, 2010 | Acer Computers & Internet
I have model A355-S6935 its a new unit. My problem is when typing the type skips out of the sentence into the lines already typed. Is this a common problem as it causes major rework and is extremely...
easy, your touching your mouse pad (square you touch to move the mouse), you can turn it off and use a regular mouse, turn off the laptop, plug in a mouse, windows will automatically detect it.
On every Toshiba notebook Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties.
Make changes to the mouse and mouse pointers in the Mouse Control Panel. To open Mouse, click Start, click Control Panel, click Printers and Other Hardware, and then click Mouse.
Good luck,
Mr.Fix-it-guy
Aug 13, 2009 | Toshiba Satellite A355-S6935 Laptop
Whilst typing the cursor moves to another part of the document
If your laptop has the option too you can turn off touch pad through a switch above the touch pad.
If you can't find this, or you don't have one, simply go to the run command and type in devmgmt.msc, ok.
Once in the device manager go "Mice and Other Pointing Devices"
look for your touchpad, right click on it and select disable.
Please note, some laptops wont let you disable to the touchpad, mine wont, but mine has an on and off key.
ON/OFF Key
Touch Pad On
Touch Pad Off
This will keep the mouse from moving whole you type, but I suggest you get a regular mouse, especially if you have to disable the device with the Device manager.
Jan 05, 2009 | Computers & Internet
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
