Question about Maytag Washing Machines
Epic 9600 model door will not open machine will not engage code comes on screen dl f
    Sergeant:
  • 409 Answers
this code means you have a door latch error. this is why the door does not open or does not work. the machine automatically shuts down when this error happens to prevent the machine from running endlessly. call a technician to replace the door lock.
thanks
Posted on Oct 02, 2008
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Washer sometimes will not work and a code comes on f dl what does this mean?
The DL code indicates a problem with the door lock. These washers need to lock the door before they fill with water. Then the door will unlock at the end of the cycle. The problem can be with the lock, the sensor that detects the lock status or the main control unit not receiving the lock message. Sometimes the wiring is the problem with the unit.
When the DL code comes on, can you pull open the door as easily as when you open the washer before starting the machine? If you can, then check if the wiring is sending the appropriate current to the lock. If the power is there, replace the lock. If the door has actually locked, then the problem is with another part of the system. Most washers will have a sheet with the wiring diagram and expected readings inside the machine near then main control board. This is accessed from the back of the machine above the wash tub.
I hope this helps.
Oct 16, 2015 | Whirlpool Washing Machines
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer has worked all day and all of a sudden wont work a dl f is flashing all lights come on but wont engage angel123@suddenlink.net
This error code means your door lock/latch has broken. Replace your door latch and you should have fixed the problem. I hope I helped you.
Sep 02, 2010 | Kenmore Washing Machines
F/dl code comes on - machine doesn't run
failed door lock error, i would first unplug the unit for about 5 minutes this will reset the board. if that doesnt work you may have a bad door latch. .inspect latch that the piece on the door that when you close door piece on the door makes contact with the latch. hope this helps
Sep 16, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
Oct 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
