First scan your file to place you will remember on the hard drive. Then opem up your email and start a new or compose a new message. Some where in the toolbars at the top - there should be an attached button (somtimes they look like a paperclip) - a select the scan file that you just created.
You cannot scan pictures directly to email. Scan the photo and save the photo as a JPG file. Open your email program, setup the email and address to your friend and then attach the scanned JPG file to this email before sending it.
Hi
Once you have scanned a document it should appear on your computer as a picture file of some sort. This depends on the scanner. If you would like to send it via email you should open an email message and just simply click on where it says attach. You then choose the picture file that you wanted to scan and then wait for it to finish uploading the file. After this just simply send the email
Hope this helps!
just scan it using the command from the computer ..after that you will find the job into the manager folder..of the scanner..from there you can send it directly ..or edit a little ..and copy into computer and attach to the email..or ..use the feature from the scanner's program to send it .. make sure you set to scan picture cause scanners have a wizard that you can set to scan image (picture Jpeg ....) or PDF ..document ..
while scanning try reducing the DPI of the scans. this will make the image smaller in size but it will effect the picture quality very little. but do keep in mind that the dpi must be atleast 70 for better picturization
If you have installed the software of the printer already then you can use the hp solution center to scan a document or a picture. And make sure that you have save the picture or document. After saving it to your computer you can open your email and put the document or picture as an attachments
After you scan your pictures, save your pictures to your computer. after that you can open your email add. Click compose message to your email add and then click attached files then browse the pictures and upload it. After that you may send your email add to your own email add and also to another email add.
