Question about Sony KV-32S68 32" TV
SONY KV-32S68 Hi, My Sony TV screen display suddenly began to go black and/or the screen image shifts way up at an angle leaving half of the screen black. Is this a fatal flaw and should I even think of trying to get it fixed? Thanks Gerald (grbgrb@aol.com)
  • 41 Answers
You have a busted capacitors around the flyback... that's why there have a low filtering in the supply... try to overhaul the capacitors usually with the high value of capacitance and voltage...
Posted on Oct 02, 2008
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony KV-24FV12 picture problem
Alright, TV has hardware problem in Horizontal section and I would suggest to set Picture Quality as Soft Mode.
Jun 20, 2008 | Sony KV-24FV12 24" TV
Sound and no picture
Hi, if your getting half a picture AND the other half is black the vertical circuit is failing, either solder is broken or vertical IC needs to be replaced, not a pricey fix, BMW Rider
Jan 04, 2008 | Sony KV-32S26 32" TV
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
No picture on a Sony KV-32V65 TV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking.
Jan 18, 2007 | Sony KV-32V65 TV
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Televison & Video Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
