Question about Electrolux Washing Machines
I have the ewf 1080 front loading washing machine, and when i turn the power button on, no other lights come on the display . when i turn the power button off ,the light fades away slowly on the power button
  • simonaadam Oct 02, 2008
    thank you very much for help
  • 172 Answers
Hi simonaadam,
If no lights are coming on when you turn the power on, you may have a bad control board. You may also be able to reset the control by unplugging the power to the washing machine and leave it for about 5 minutes. Then plug it back in and check the controls again. If you need the control please let me know and I can have one shipped out right away. Thanks and I hope this will FixYa
Mike
Posted on Oct 02, 2008
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
Why wont my ewf 1080 electrolux spin
Most likely the washing machine is stuck in Hold mode. Check if you have the spin speed knob at the correct setting.
Manual is available from here
http://www.manualslib.com/manual/616814/Electrolux-Ewf-1080.html#manual
Check the parts and schematics at this site
http://spares.bigwarehouse.com.au/index.php?cPath=64689_77309_77544&sort=2a&page=1
Aug 29, 2014 | Electrolux Washing Machines
My Electrolux EWF 8556 Front Loading washer wont Start
Hi I would check the plug to see if the wires have come loose or the fuse is gone in the plug this can happen at any time and its the last place you always look, the plug looks fine but
Nov 15, 2017 | Washing Machines
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
I have a ectrolux ewf 1074 with the padlock symbol
you need to turn machine on and hold the option and extra rinse buttons simultaneously for 6 seconds, the symbol will go and you'll be able to use your machine again as usual
Aug 02, 2009 | Electrolux EW1000i Front Load Washer
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
Whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Mar 12, 2009 | Electrolux AWF1235 Front Load Washer
Electrolux EWF 1087 - Power on, light goes orange, nothing works.
Hold reset and start buttons down, while turning on. Hold down for about 10 seconds.
If you're getting an E90 error code, which means communications error, it means you have a dodgy connection between the main board and the control panel.
Disconnect the power completely, open up the top of the machine and reseat the plugs on both ends on the blue ribbon cable connecting the front panel display to the main board. (The main board is the big white plastic thing with all the wires running into it).
Do the reset steps when turning on again, should be good to go, otherwise it's a bit more serious and you'll need the tech back.
Feb 28, 2009 | Washing Machines
Washing Machines Logo
614 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
