Question about Yamaha Audio Players & Recorders
I am operating a Yamaha PM1D and I am getting a "Control Line A Disconnected!" message coming up randomly, stopping any board control. The second line is not taking over, as I would expect, and this is a problem. Also, I noticed that both lines were assigned to "1", and I changed the second to "2", which temporarily fixed the problem. However, when it came back, I was not able to fix it unless I unseated and reseated the BNC cable. Why is the redundant line not taking over?
robotek
  • 1512 Answers
SOURCE: yamaha kx88 keyboard midi controller problem.
Hi there, check over all your MIDI leads also. MIDI is a current operated system and is very prone to misfiring if all connectivity is not A1.
Posted on Mar 21, 2008
  • 12 Answers
SOURCE: yamaha receiver RXV-1400 turning off after 3 seconds.
Hi
there are several reasons, but the most common is because a high power trasistor is shorted, most yamaha receivers use the same names for the failure signals, such as PRD, PRI, PRY
The PRI is the signal that "tells" to the microprocessor that something is wrong with the power amplifier stage. so my recommendation is that look with the ohmeter a power transistor shorted usually if one if damaged, the next one or complimentary is too, there is a small transistor between the two big ones, usually is the number is D1915, if this is damaged, USE the SAME, also look for resistors damaged, specially the low value like the big white this resistor is 2 in 1 and some times just one resistor opens.
I hope this helps
Miguel
Posted on Apr 25, 2008
  • 4 Answers
SOURCE: Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Posted on Aug 04, 2008
cnavarro
  • 2460 Answers
SOURCE: LINE NOT ASSIGNED
Since, by default, you have either 4 or 8 lines minimum, do they appear on other phones and is there anything on the buttons? Press PROG and line 3 button. If the display shows CO 003, you have another problem. If they show blank, dial 0 3 and press ENTER. Do the same for line 4 (using 4, of course).
Carl
Posted on Oct 24, 2008
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
My Yamaha RX-A1010 turns on and shuts off by itself on occasion. It also randomly switches between inputs by itself.
Your receiver may be detecting random signals from some other source. Infrared is pretty much line of sight but RF can come from anywhere.
Aug 29, 2016 | Yamaha RX-A1010 Aventage Audio video AV...
89 comanche 4.0 vacuum line disconnected near passenger headlight - no cruise control
You should have a vacuum line diagram under the hood of your car you can buy the haynes repair book for your vehicle at any autozone or advance auto someplace like that
Mar 26, 2013 | 1989 Jeep Comanche
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
I have a front loading Maytag Neptune washer. I am constantly gettings the "SUDS" message even when I am hardly putting any soap in. I will also get the "No Drain" message, which used...
This typically happens when you use regular detergent instead of HE detergent, which stresses the pumps. Are you using HE detergent?
Also check for blocked drain hose or clogged water filter.
Apr 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
This message appears on my screan in no particular timing; "OSD MAIN CONTROL LOCK"
This is a problem on the board with the buttons located at the bottom of the monitor. Must be disassembled the monitor and this board must be disconnected. This is the quick and easy solution.
Dec 24, 2010 | Philips 190C
Control panel continously beeps with message to
Could be a faulty control as you suspect but also may be a bad keypad. If the "start" button has no effect I'm suspecting the keypad first.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | GE Profile JT912 Electric Single Oven
Possible interface board. Tell me I'm wrong!
You NOT wrong sorry, sounds as if your controller may have been hit by a power spike surge :(
Mar 19, 2010 | Dryers
Wurlitzer omt K99 the cd will stop during play
I seem to be having the same problem and all signs point to the serial control board board Pt# 0046630 under the player. The symptoms with mine were randomly cutting off songs about 20 sec after song start and returning disc to carrier. It started mostly when juke was first turned on (cold) and then progressed to all the time and now display on cd board is dark only randomly coming to life then dead again. power on the sub transformer is good and when it comes to life player works well. I am sending the board to be repaired.
Feb 07, 2010 | Wurlitzer Jukebox 1015 One More Time...
21 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
