Question about Panasonic Televison & Video
Lhorizontal line at centre ,rightside of screen no picture sound ok panasonic 1992
Panasonic modelPC-29XF10A
  • Anonymous Mar 21, 2009
    Blue line in middle..dashed green line to the right. Sound no picture
  • 4,234 Answers
This is a failure of the vertical deflection circuit. If you can solder, you can fix this yourself. If you wish to attempt the repair, please update this and I'll provide additional details and instructions.
Dan
Posted on Oct 02, 2008
  • ABRsvcs Oct 08, 2008
    Look for a small flat IC attached to a heat sink that is marked LA7838. That is the vertical IC. Try resoldering the pins on that IC first. If that does not resolve the problem, replace the IC. There may be capacitors in that circuit that need to be changed as well, but those parts will alter the picture not prevent any vertical sweep. Update this with your progress and we'll address any other problems if and when they occur.
    Dan
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
I have a CRT tv and the picture is just a thin band in the centre of the picture tube. The sound is ok
That is called "Frame Collapse" because the picture "Frame" has collapsed into the single horizontal line.
It may be caused by dry joints or output failure of the frame output stage.
A fairly inexpensive repair.
Mar 03, 2011 | Panasonic TC-21PM10RQ 21" TV
My TV picture has collapsed to a single horizontal line
If it is an standar analog tv, I'm sorry to tell you but, is time to get a new one.
Dec 05, 2009 | Panasonic Televison & Video
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
Green line in middle of tv when switched on
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Jul 15, 2009 | Panasonic Televison & Video
Th-50px70b
when doe s this happen on hd tv bad signal on antenna will cus ethat to happen heavey comprsed dvd bunred will also do it may need better antenna ok
Oct 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic 32inch tube tv problem
picture is bouncing and sometimes i have a long line across the screen only
Sep 11, 2008 | Panasonic Televison & Video
Red lines on screen when recording
Important Notice
Digital 3CCD Camcorder
Panasonic has discovered a premature component failure with a limited number of PV-DV953 (2003 Model) and PV-GS200 (2004 Model) 3CCD camcorders, which may cause an abnormal camera picture (incorrect color reproduction, reddish, noisy image, etc). This anomaly is limited to a specific range of serial numbers listed below.
If your camcorder demonstrates the specific symptom and falls within the serial number range, Panasonic will repair the camcorder free of charge.
Please call the following toll-free number for assistance in receiving a free repair:
Panasonic Call Center: 1-800-973-4264
Model # Serial Number Ranges
PV-DV953 (2003) E3Hxxxxxx, F3Hxxxxxx, G3Hxxxxxx, H3Hxxxxxx, I3Hxxxxxx, J3Hxxxxxx, K3Hxxxxxx, L3Hxxxxxx and A4Hxxxxxx
PV-GS200 (2004) C4Hxxxxxx and D4Hxxxxxx
Nov 19, 2006 | Panasonic NV-GS200 Mini DV Digital...
Televison & Video Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
