Have a coleman evcon furnace model DGATO56BDD. blink code flashes 3 times with no diagram to know what the problem is. the furnace blows cool are instead of warm.
  • 1 more comment
  • mkiceman Oct 03, 2008
    My furnace is flashing three times and the diagram says the air combustion switch is stuck open. I called a furnace repair person and was told to shake the furnace to get the switch unstuck. It has worked in the past, however it is not working anymore, Help?
  • Anonymous Oct 16, 2008
    1. I have a Coleman Evcon # DGAT56BDD , Indicator light indicating centrifugal switch stuck open . Same problem last year, after several attempts over 3 days it started to working . Worked fine all winter
  • Anonymous Mar 31, 2014
    furnace will not light nor blow, red light on, green light blinking, remote on but unresponsive with new batteries.
Your centrifical swith is stuck open on your blend motor. I found that removing the blend motor housing and spinning the stuck motor (from setting over the summer) will get you out of a bind ,.but you may end up needing this centrifical switch (locatedon the bottom of the blend/fresh air intake) motor replaced.
Posted on Nov 07, 2008
  • Chris Cunningham
    Chris Cunningham Sep 18, 2011
    Thanks so MUCH, morefords!! Your tip just saved me a pricey visit from my furnace repair guy.. I just took off the blending motor myself.. turned the motor a few times, and viola!! My furnace is once again running like a trooper!
  • 3 Answers
This problem usually is caused by the Inducer motor or combustion inducer blower failing to create negative pressure to close the switch... I would check to see if the motor is going bad before I put a pressure switch on. if the motor sticks at all it is going bad and will fail you on the coldest night!! then you'll wish you replaced it...
HVAC service tech
zac
Posted on Jan 21, 2011
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Indicator blicks 3 times replaced combustion air switch but did not resolve problem. what do i do now?
there should be a diagnostic code that will tell you what 3 blinks mean for that model. look on door inside cover. tell me EXACTLY what it does at start up. small draft motor comes on? you see a glow from hot surface ignighter? gas comes on? flame on? it should run in this order.
Coleman furnace bgm10016ax 4 blinks
Usually on a metal panel you have to remove to access the board there is an electrical diagram. On the side of that is usually a description of what specific blinking codes mean.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
BGU10016A BLINKS CODE 9
www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Nov 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Coleman Evcon Furnace Model G8T10012UHB11A
you probably have a cracked heat exchanger which is causing the rollout switches to trip.even the tiniest of cracks will cause the fan to blow the flame back into the unit and cause them to trip. check the heat exchanger for even the tiniest of cracks if so replace it. and be sure to have a carbon monoxide alarm in your home.
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
1,998 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
