Question about Kenmore 19365 Computerized Sewing Machine
Kenmore 19365 I need to know how to drop the feed
If you are asking how to drop the feed dogs, the lever is located underneath the free arm bed on the back side of the machine. So you must first remove the free arm bed. To drop the feed dogs, push the lever over to the side. To raise them back, push the lever the opposite direction, back where they were originally. You will not actually see the feed dogs move until you turn the handwheel toward you. I hope this helps. I do not know how old your machine is or anything. I believe mine is about 5 years old or so. Good luck
Posted on Dec 05, 2008
Bobbin holder part for Kenmore 19233
ebay an amazon though many folks trade on craigslist an so many more here is maybe what you need see
BOBBIN WINDER KENMORE 385 18080 18230 19030 19150 19153 19157 19233 19365...
Jan 05, 2015 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19365 up/down needle button works, but will not sew.
Usually that means that the needle is installed incorrectly or your timing is off so that the needle is not catching your bobbin thread. First check to make sure that you have the correct needle for your machine and that it is installed correctly. If that is right and it still is not catching then your timing might be off and unless you know how to fix that you will need to take it to someone. Good luck.
Oct 01, 2014 | Kenmore Elite Clothsetter 19010
The feeding teeth on my kenmore model number 15813513 have dropped and i dont know how to get them back up to feed the material through
since it's a kenmore sewing machine call sewvacdoctor.com
and ask them how to get the feed dog back up
(800) 544-5858.
Oct 22, 2012 | Kenmore Sewing Machines
I would like to learn how to clean and oil my Kenmore model 19365 sewing machine plus any other routine maintainence. I also am having prolems with my bobbins not staying in the bobbincase while sewing. I...
If, I were you I would take my machine to the Sears sewing machine department and ask the salesperson how to do these things. They are usually very helpful, and if you need a manual they can order it for you. Do not be afraid to ask for help because just remember the only dumb question is the one that isn't asked.
Dec 28, 2010 | Kenmore 19365 Computerized Sewing Machine
Machine is sewing along just fine and then makes a wad of thread on the underside and stops sewing. I removed the plates and cleaned out but it is still doing that. Seems to pull the top thread and...
More than likely it is your top threading that is not right. Try seating the thread in the tension discs. To do this, rethread, now with the presser foot up, pull the thread, it should feed smoothly. 'After this, put the presser foot down, it should barely move. Hope this helps.
Nov 14, 2010 | Kenmore 19365 Computerized Sewing Machine
Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Sep 20, 2008 | Sewing Machines
Stopping
What machine? If it is a 19606/19365 and you are using stitch number 19, then tha twould be normal. It is a tacking stitch. If it is not a electronic, please reply with a model number and I'll try to help!
Thanks,
Bonnie
Jul 29, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kenmore 19365 decorative stitch will not stitch
You have to key in the number for the stitch on the stitch panel
Jan 22, 2008 | Kenmore 19365 Computerized Sewing Machine
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19365 Computerized Sewing Machine Logo
116 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
